Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs (Tech)
Sign in using an external account
Register Forgot Password?
Search
Welcome to Mustang Forums!
Welcome to Mustang Forums.
A woman's project: 68 Fastback
Old 04-04-2014, 08:42 AM   #941
racer_dave
racer_dave's Avatar
Vehicle: 1967 Mustang Fastback
Lynn,
Thanks for the update!!! I can feel the frustration, for sure. So the racer in me (who's used to having to modify everything!) has a couple questions...
1- If you go to a manual rack, would you gain some pan clearance? I'm thinking without the servo you could maybe get the extra wiggle room? It might be a bit harder to turn in a parking lot, but certainly not as hard as a manual steering box car would have been. Would adjusting the rack mount help?
2- What are the dimensions of the lower crossmember? Can you thin that out to drop the engine another 1/2" or so? If that causes another interference, what hits?
3- Stamped steel pan, or cast aluminum? Steel pan can be modified easier.
4- You said the compression is too low to run naturally aspirated, what is it? Pistons domed/flat top or dished? What is the chamber volume of the heads?
5- All this started because of the high volume oil pump? Why this pump? I mean obviously you want good oiling, but there are lots of pumps on the market, if you switch pumps does that open up more pan options? *** edited- I can't stop thinking about this... I keep coming back to the pump/pan... What part number is the pump? pans? There's got to be a workaround between these two parts. If we can figure this out, then the rest works. Pics of these if you have them. Got to be a way to fix this...
Post us some pics of the pan/block/clearance issues, of the intake, oil pump, rack install so we can all stare at it a bit. I know that's going to feel like picking at a scab but please think about it.
You've been kind enough to share this build from day one, let us give back by helping find a solution to all this. I bet we can figure it out with enough eyes on it.
__________________
The gas pedal fits best right up against the firewall, so I figure it should be there as much as possile
racer_dave is offline   Reply With Quote
Old 04-04-2014, 11:35 AM   #942
NoReins
NoReins's Avatar
Vehicle: 1968 Ford Mustang Fastback
I can answer some of your questions now but the others later and I can post pictures later. Basically at this point we want to find the easiest solution. We already know we have to pull the engine out regardless so we've been mentally prepping for that. Probably have to pull the nose and of course the hood.
Moving the rack down won't work because it's already so close to the boot on the lower control arm. I'm talking 1/4 inch. Pictures will show later. I don't want to go manual rack - this set up is supposed to work! There is a possibility of drilling out the holes on the cross member to move to rack a little bit BACK which would free up a smidge for the clearance of the pan. But again, if this has "been done a thousand times" then it should either A. Work without mofidying or B. Fix the design so the rack doesn't sit HIGHER than the crossmember causing the pan to literally lay on the rack. Cannot drop the engine without modifying the pan AND modifying the mounts that Rusty has already modified. Again, we need the most simple solution. Hindsight it would have been better to have modified the pan not knowing we'd have clearance issues on top. We purchased the Canton oil pan because with the s/c we wanted to use the HV oil pump that the engine was designed for (the Ford Motorsports pan that we did initial mock up with would NOT clear the pump). Rod and Custom Pan numbers are 15-690 and it's fabricated steel.
Engine compression is 8.9:1 with forged pro pistons. Heads are Edelbrock Performer.
We've been through 3 oil pans. I'm tired of buying oil pans. I'm tired of buying everything 3 times. I'm tired of all the lies, and being misled.
__________________
NoReins is offline   Reply With Quote
Old 04-04-2014, 02:41 PM   #943
racer_dave
racer_dave's Avatar
OK, went back and looked at pics from the thread, and also found the thread on the VMF that had some more pics.
It looks like the only issue with the Canton pan is where the front bulge comes down, and that is hitting the rack? If it was me, I'd look into modifying that pan to give more clearance at the rack. It will depend on where the pump is in relation to the pan, but even if you only gain 1/2" it might be enough.
So that's the way I'd go. It's cheap and it lets you get the motor back down where it needs to be.
I know this was all 'supposed' to work and it's beyond frustrating, but all you can do now is adapt.
__________________
Old 04-08-2014, 09:45 PM   #944
chillininnh
Send a message via Yahoo to chillininnh
I feel your pain. I bought many things on my build (headers, rack&pinion kits, seats etc.) 2 and 3 times. It sucks. Hang in there and move methodically, you'll get there.
__________________
69 Mach 1 418W/TKO600/RMP Front Coil-Over/TCP Manual R&P/FR Tilt Column/GW Subs/GW Lowering Leafs/GW Del-A-Lum/Factory Power Front Brakes/3.70 9" Auburn Diff/Painless Wiring/ProCar Elite Lumbar
Project Pics
http://s63.photobucket.com/albums/h127/chillininnh/
chillininnh is offline   Reply With Quote
Old 04-09-2014, 09:14 AM   #945
Snipe656
Vehicle: 1967 Ford Mustang GT
With different heads you could probably end up with some decent compression for an NA setup. Guess it just all boils down to preferences, 8.9:1 is not really all that low of a compression ratio after all when considering that was about the stock compression ratio for pushrod V8s when Ford still was putting them into cars before the mod motor switch overs. I do not know anything about the particular heads you have but I once took a motor making similar compression and got it to above 10:1 via some major milling of the heads to drop the chamber sizes. But that route was taken in order to race in a specific class for a specific race. We even had to mill down the intake so things would fit right, I will dare say we went too far down with the heads. Had we not been trying for that specific need then I'd opted to going to a different brand head that would already be smaller and designed for that.
Snipe656 is offline   Reply With Quote
Old 04-09-2014, 09:23 AM   #946
racer_dave
racer_dave's Avatar
I looked up the edlebrock heads and the CHP website and tried to figure out how they got to the 8.9. I could get to 8.7 using one of the pistons listed on their site, a .202 head gasket thickness and 90cc heads. If that's the case, then if they swap to the 60cc heads they gain a lot of compression. Might need to run a thicker head gasket if they don't want to use octane boost all the time. Otherwise, mill the 90cc heads a touch. You don't want to go above 10:1 if you're wanting to run pump gas.
As for the space issues, I don't think they'll find the inch they need in any one place, but a 1/4" here and a 1/4" there adds up in the end. I have to do that with the racecar all the time. I can't find 10lbs to get rid of, but I can find 1lb 5 times and 1/2lb 10 times and get the same result. I'm sure they'll get it, but it's difficult when it's so frustrating for stuff that is supposed to work.
__________________
Old 04-09-2014, 03:02 PM   #947
NoReins
NoReins's Avatar
Quote:
We did give this some thought, problem being we did not want to hack up a work of art ($$!). We were also worried about the pan clearance with the HV oil pump. It seems like the way to go right now is to swap the pump and run the Ford Motorsports pan- what's another oil pan anyhow! I appreciate your throughts and willingness to help Dave!
Thank you for the support chillininnh! I know we will get there eventually, you just have to step back from these projects after awhile.
Quote:
Someone else told us this as well. However, they also said there was a huge power loss by doing so. I suppose they had to run this ratio to comply with emissions? I am not that much of an engine guru (can you tell, lol). We are going to talk to a local engine builder and see what he can make of the parts we have.
Dave you are beyond me with the head milling and such. We are trying to learn the in's and out's of engine building, but I guess it is like anything else on these cars, learn as you go.
Thank you guys again for your thoughts, help and encouragement! We will get things straightened out I know. Luckily we have plenty of (more exciting) parts of Eleanor to work on in the meantime.
__________________
Old 04-10-2014, 08:12 AM   #948
Snipe656
Quote:
Or it could been for fuel quality issues. I have found if I step much above 9.5:1 compression that I would sometimes get some "pinging" after filling up at certain gas stations. Although it be all in how it is tuned. I ran a 302 engine with 10.25:1 compression and a Vortech making 10-12 lbs of boost for awhile in a daily driver. But to do that I backed out a ton of timing and thinking back was probably drowning the engine with fuel.
For your motor I'd say pull one cylinder head off and cc the chamber on it. Might be able to get a local engine builder to cc it for free or dirt cheap. It is a real simple process to do and gives you an idea of what you have since always a chance something was done to them when the engine was built. Would be nice to know the cc of your pistons too but can't honestly say I ever tried to do that with the shortblock assembled though guess it is possible to get a decently rough idea. From there you can figure out the compression and see if it is what you were told. It also should help you with those numbers to be able to figure out some "affordable" methods to adjust the compression to a number you'd like to be at.
Of course a whole other option is just sell the engine you have and find one more suited for an NA goal, if that is the route you definitely are going to take. Seems nice "used" engines come up for sale quite often as people switch their projects around or run out of funds to finish their projects.
__________________
-- Admiral Aaron
Old 04-10-2014, 03:13 PM   #949
fastbackford351
Foghorn Leghorn
fastbackford351's Avatar
Vehicle: 1967 Fastback & 2002 GT Convertible
Dang, that's looking good.
__________________
Government Warning:
Governments are extremely dangerous.
Death, imprisonment, theft of property
and loss of freedom will result from
giving them too much power.
fastbackford351 is offline   Reply With Quote
Old 04-14-2014, 05:29 AM   #950
NoReins
NoReins's Avatar
I'll get back to the engine chat later but here are a few pictures I took last weekend. It was finally sunny and warm enough so we pushed her out to see what she looked like in the sun.
Click the image to open in full size.
__________________
Old 04-14-2014, 07:09 AM   #951
chrisKcode
Vehicle: 65k code fastback
Oh my, that does look fantastic, excellent job and looks wonderful in the sun.
Sorry to see your troubles on the engine and hope you get there soon.
Chris
England
chrisKcode is offline   Reply With Quote
Old 04-14-2014, 07:18 AM   #952
racer_dave
racer_dave's Avatar
Yeah, that is bad a$$. Incredible job so far!
I showed this thread to my daughter and she was like 'You mean a girl is doing that!' (I guess she didn't notice the hubby working to....) She's pretty fired up to work on her car.
Keep going, looks terrific, although 'terrific' doesn't quite do it justice.
__________________
Old 04-15-2014, 11:32 AM   #953
Stangatic
Vehicle: 1966 Ford Mustang
Wow, I just caught up after months of not check out what's been going on. I usually get email alerts whenever someone posts to this thread or NoReins makes an update, and started to get worried. (can you say Devoted follower!!!)
I really hate when these companies state that their products will work with XYZ application, but when you get the item in and installed it's far from the truth. I had problems with QA1 suspension parts (on my 2000 GT) and the MSD EFI I got on my car now. The MSD EFI was a $2200 mistake! Hearing what you had to say almost turns me far away from using R&C setups. So maybe Ill go back to the drawling board with my planned setup.
There are plenty of stout engine combos out there that you can go with. You might want to explore with the DART 302 blocks or the Boss Ford blocks for more cubes. I would sell the supercharger alone and the long block separately since they don't work together.
I know you wanted to keep it as move correct as possible, but wouldn't the cheaper route be getting the larger Eleanor hood?
__________________
1967 Convertible V8 - Frost turquoise
1966 289 Mustang coupe, Sahara Beige w/ black interior: Tuff Dawg Engines 302/ 375hp 393tq w/ Comp Cams ***** Thumpr 287TH7 Cam. Ported, Polished, 3 angle valve job, Performer RPM casting heads. 9.5 comp ratio. Edelbrock 650 AVS carb. Promotion Powertrain 295SHD T-5. Gt spec suspension. Pacer 15" wheels.
2000 Gt convert ***SOLD*** :*(
Stangatic is offline   Reply With Quote
Old 07-16-2014, 05:33 AM   #954
NoReins
NoReins's Avatar
No, we don't want to go that route and even if we did the back of the hood would still most likely not clear.
Anyway, we have not touched the car in many months. But, she will be having a photo shoot this weekend so we are trying to make her look like she runs. A few nights ago we put the grilles in.
Old 07-16-2014, 09:54 AM   #955
Stangatic
Looks good! Any developments on the engine?
The Eleanor project that I have been working on is at a stand still too. Since coming back from body and paint, my good friend that I am helping (it's his car) appears to have lost interest; which is a shame because all is left to do is put everything back in the car and buy an engine. I might try to purchase it from him to build and sell to provide additional funding for my Eleanor convertible project.
__________________
Old 07-16-2014, 09:55 AM   #956
racer_dave
racer_dave's Avatar
That looks so wicked... Who is the photo shoot for?
I know you all needed a break, but keep going on her... I guess for encouragement I'll say to you the same thing I say to my friends when we're bitching about racing costs/parts that don't fit/wrecks/lack of sponsors etc... "If it was easy everyone would be doing it." And as always, if there's anything we can help with, let us know...
__________________
Old 07-16-2014, 01:42 PM   #957
Roystang
Roystang's Avatar
Great looking Mustang keep up the awesome work!
Roystang is offline   Reply With Quote
Old 07-17-2014, 03:50 PM   #958
NoReins
NoReins's Avatar
Thanks guys! No development on the engine. Right now the only thing she's doing is serving as a very pretty garage ornament Everytime I go into the garage I do a double take. She is so pretty, the pictures don't go her justice. We'll get back at it soon, I promise. Time and money, time and money as we all know!
Here is a shot of the front finished with her grilles and lights. I can't get enough of her. The owner Southern Polyurethanes (we used SPI Universal Clear and SPI epoxy) requested a few shots for the Southern Polyurethanes product catalog.
__________________
Old 07-17-2014, 03:52 PM   #959
NoReins
NoReins's Avatar
And I just realized, after almost 5 years she finally looks like my avatar! Wow, I can't believe it
__________________
Old 07-18-2014, 07:36 AM   #960
racer_dave
racer_dave's Avatar
Then it's time to update the avatar pic... A question I didn't see covered in your build- whose wiring harness did you use? would you use the same one again or a diffierent brand? pros/cons?
__________________
MustangForums
Ford Mustang
Paid Advertisement
1968, 200, 68, 71, classic, down, fastback, fold, ford, i6, lines, mustang, mustangs, non, project, sale, vacuum, woman
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Emails Backup
