A woman's project: 68 Fastback
Old 12-03-2013, 06:24 AM
  #871
NoReins
NoReins's Avatar
They're still finishing up the hood and decklid but the car looks excellent so I thought I'd share some pictures I took with my phone. I did my best to capture how good she looks but truthfully they don't do her any justice. Oh, and the hood does not clear the intake so we will be working out that issue when we get her back home.
NoReins is offline
Old 12-03-2013, 06:52 AM
  #872
AJ06GT
AJ06GT's Avatar
Wow, you can definitely start to see the final product taking shape now! Bet you can't wait to have it home!
AJ06GT is offline
Old 12-03-2013, 03:54 PM
  #873
NoReins
NoReins's Avatar
You have no idea.
NoReins is offline
Old 12-06-2013, 11:02 AM
  #874
stillridin
stillridin's Avatar
Wait a minute! So your down here now?
stillridin is offline
Old 12-07-2013, 07:16 AM
  #875
NoReins
NoReins's Avatar
I wish! We are back home now.
NoReins is offline
Old 12-13-2013, 06:02 AM
  #876
NoReins
NoReins's Avatar
A little more progress.
NoReins is offline
Old 12-17-2013, 09:33 PM
  #877
hightower2011
hightower2011's Avatar
Guess who's still jealous?
Me.
hightower2011 is offline
Old 12-17-2013, 10:15 PM
  #878
Gun Jam
Moderator
Gun Jam's Avatar
How much does the intake not clear the hood? im assuming air filter hits?
Ron Morris performance makes a set of totally badass motor mounts. This mounts can be purchased in "dropped" format and they will lower the entire engine 1/2 inch. If you have clearance below the engine (drag link, oil pan) they could work.
-Gun
Gun Jam is offline
Old 12-18-2013, 09:26 AM
  #879
NoReins
NoReins's Avatar
Thanks for the suggestion with the lowering mounts Gun Jam. I am not sure they would work with the R&C cradle mounts as they are designed to mount on the factory cross member and the R&C kit uses it's own mounts. Beyond that, the bigger problem is that the engine can't go any lower due to the rack clearing the pan. We did think about lowering the rack in the cradle, ie moving the mounting holes down, not sure if this would affect the steering linkage geometry, but also something to check out. The intake that is on the engine is the Edelbrock Performer EFI, which when combined with the upper is around 12". This seems pretty tall and may be our main issue. Our clearance with the hood is probably around an inch?, but we will measure exact when she arrives home. It seems as though a sealed carb enclosure may be our best bet? (Can you tell we have given this some thought?) lol
Sealed carb enclosure:
NoReins is offline
Old 12-18-2013, 11:30 PM
  #880
stillridin
stillridin's Avatar
Can you machine down the runners on the intake? Or will it hit the fuel rails, or maybe the valve covers. Also you'd have to use the small diameter distributer with that enclosure. How about just a blow through carb and hat.
Quick Reply: A woman's project: 68 Fastback
