Advice needed on 67 Mustang - Page 13 - MustangForums.com
Old 04-06-2011, 12:10 PM   #121
eZ
eZ's Avatar
Should be real simple to remove that crossmember?
eZ is offline   Reply With Quote
Old 04-08-2011, 02:43 PM   #122
Novice-Owner-Marc
Quote:
eZ thanks for the help. I really appreciate it. This simple help, solved my problem.
Novice-Owner-Marc is offline   Reply With Quote
Old 03-24-2012, 08:19 AM   #123
Novice-Owner-Marc
Hello all,
Started this thread/project a loooooong time ago. Financial and some personal issues took importance from the task, but I'm back around. I'll drop statuses as things happen. I'm running the wiring now for the taillights. Once that's done I'll post some links for advice, comments and thoughts. Talk to you all soon.
Old 03-26-2012, 08:59 AM   #124
Novice-Owner-Marc
So I am trying to plan out the exhaust on my project. Recap is, I have a 67 coupe with a 351w crate engine and AOD from an 89 Mustang. So with that said, I got a set of headers that are going to a 1 5/8" opening I believe. Although I'm not sure if I should go dual or single exhaust.
Thoughts, opinions, comments?
Old 03-26-2012, 10:42 AM   #125
hightower2011
hightower2011's Avatar
I definitely think you should do dual exhaust. It shouldn't be too expensive, you could get an aftermarket exhaust or factory for pretty cheap I would think.
hightower2011 is offline   Reply With Quote
Old 03-26-2012, 07:59 PM   #126
Novice-Owner-Marc
Last I saw on MU it was about $1200 for a dual exhaust. IDK I guess that's doable......
Old 03-26-2012, 08:29 PM   #127
hightower2011
Quote:
I guess those were with headers.
Here's these minus headers:
http://www.autopartswarehouse.com/de...e&apwid7yu3aLe
More of a factory option:
http://www.cjponyparts.com/product.a...paign=shopping
So with a nice pair of headers and that flowmaster exhaust, you'd be good to go. I'd think you could get nice headers for $400-600 or so. Total you should come in under $1000 I'd assume.
Old 03-27-2012, 04:14 PM   #128
Norm Peterson
Norm Peterson's Avatar
On the driver's side, the TV cable to your AOD must take absolute priority on space allocation over the D/S exhaust. Even if you have to modify the end of the D/S header itself.
I'm not making this up - somebody I know (not on the forum) didn't believe me, hooked up the C4 kickdown link instead, and burned up his AOD in under 200 miles.
Norm
Norm Peterson is offline   Reply With Quote
Old 04-24-2012, 08:50 PM   #129
hallmarkreno
Watch Craigslist for 302 and AOD or T-5 combinations. Occasionally you can get an assembled combo for a great price!
hallmarkreno is offline   Reply With Quote
Old 04-28-2013, 04:07 PM   #130
supermario
supermario's Avatar
This is exactly what Im doing at the moment. The 67 engine bay can fit a 390, so the 351 is a good fit and Lost of power and a perfect match for that AOD. Or just buy a FRPP or Edelbrock drop in Crate engine and an AOD.
oops brought this back from the dead.
Quote:
Originally Posted by 408 Stroker View Post
I have a 351 windsor stroked to a 408 forged with a 850 card and alum. AFR 210 Heads and hyd. cam and a AOD for that long trip and used the same gas tank(stop to fill it alot!) just my thoughts!
supermario is offline   Reply With Quote
Newbie on deletes MusBBad95 New Member Area 7 08-17-2015 09:39 PM
2003 V6 a/c blowing hot air. need help with relay SANDY21 V6 (1994-2004) Mustangs 3 08-17-2015 02:41 PM
Cam swap on 68 289 ding56 Classic Mustangs (Tech) 3 08-14-2015 02:40 AM
cruise issues defarmer 5.0L (1979-1995) Mustang 3 08-13-2015 06:40 AM
Just swapped motor exhaust want fit daytooday Motor Swap Section 2 08-11-2015 09:22 AM
338, 3550, 67, background, bb, boss, cable, checks, crossmember, drake, edelbrock, install, mustang, scott, tv, unisteer, vin
