opinions wanted
Old 09-01-2010, 09:21 AM
SJs 66coupe
SJs 66coupe's Avatar
Default opinions wanted
I am going to replace my valve covers and figured this would be a good time to add some new looms to organize my plug wires better at the same time.
Any opinions on which style (see two links below) might look better? Not saying these exact ones but the links are to give you an idea.
http://www.pawinc.com/shoppingcart/S...9409&catid=604
or this concept
http://www.cjponyparts.com/product.a...cd2=1282681235
SJs 66coupe is offline
Old 09-01-2010, 09:56 AM
kalli
kalli's Avatar
there's two basic ways to route the wires.
One is 4 each to valve cover center and use the ford racing style to distribute from there
the other is go around the valve covers and so they plug in from front to back. This I find looks a bit cleaner, but for that you'll need cut to fit wiring.
To hold them up there's two different ways. Either the bracket you showed or just simply the ones where you have 4 clips, 3 clips, 2clips ...
kalli is offline
Old 09-01-2010, 10:02 AM
SJs 66coupe
I'm tempted to go with this style
Just not sure they would look that much better at roughly 5 x's the cost
Old 09-01-2010, 10:08 AM
nassaubayman
nassaubayman's Avatar
I've seen cars with the option #1 holders. I think that looks nice and clean. I considered doing that, but couldn't find a set for less than $90. I like them, but not that much. For the price you found, I would have gone that route..
I put Ford Racing valve covers and a Ford Racing air cleaner on my Mustang. For that reason, I like your option #2 also. I think I'll get a set of these. Here's how mine looks now:
nassaubayman is offline
Old 09-01-2010, 12:19 PM
mr_velocity
mr_velocity's Avatar
Sure would like to see a picture of these installed.
mr_velocity is offline
Old 09-01-2010, 12:34 PM
Houndstooth
Houndstooth's Avatar
I have the first style on my truck and the other style on the Mustang. The first ones are definitely cleaner and they look really nice but they are expensive. The Ford Racing ones work fine, just depends on how fancy you want 'em. I got the ones for my truck at O'reilly for around $60 but you will need to custom fit your wires. I'll try to get some pics up later.
Houndstooth is offline
Old 09-01-2010, 08:50 PM
BeastMachine67
BeastMachine67's Avatar
I use to have a set of these on my old mustang. I didn't really like them much. they got in the way when I needed to work arould the engine but, if it works for you go for it.
BeastMachine67 is offline
AMAlexLazarus
AmericanMuscle.com
21
04-04-2020 02:16 PM
baron95
09-06-2015 09:24 PM
whatsup62
09-03-2015 01:38 PM
kdryan
08-21-2015 04:01 PM
Quick Reply: opinions wanted
