Need help with new wheels and tires
#21
#22
There's a lot more to handling than what you can extract in steady-state cornering. Crispness of turn-in response and linearity to name a couple of items - are they slightly "sluggish" or do they go a bit numb, start plowing and shrieking back at you long before you've reached their peak? Or do they respond "right-now" and hang in there without getting sloppy?
Norm
Norm
Just a little more tire tech FWIW - it's only at the "H" and higher ratings where you are guaranteed to have a belt cap ply in the tread region which adds a little stiffness in addition to their primary job of controlling belt ply deformation due to higher centrifugal force at the higher speed ratings.
Norm
Norm
I wonder what the best available tire is for 15 inch wheels. I have seen the G Force tires, but have never heard of Firestone SZ50.
#23
Thats true. I've seen several of your videos. If I drove my car like that all the time, I would probably replace the BFG TAs with something better.
#24
A sidewall stabilizer performs a similar stiffening function in the lateral direction and keeps the tire tread more closely aligned with where your steering input is actually pointing the rim. BFG notes that it's a feature borrowed from the tire lines with higher performance intent, so even though they're probably using it to "crutch" these relatively tall profile 'S' or 'T' rated tires into behaving better, it's still a good thing. A tire with this feature is certainly a "shelf" above an otherwise identical tire that does not.
Norm
#25
So with the 245's in the back when I hit big bumps my fenders would cut into the tires. So I got some adjustable air shocks that can lift the rear almost 3" and that solved the problem. Now I'm debating on going with maybe some slightly taller 265's for a muscle kinda look. What do y'all think?
pic:
pic:
#26
So if you put in air shocks and it raised your rear 3 inches and you took that photo....then I would suggest you put new springs and shocks in the car....if fact I would suggest that regardless of if that is a before or after photo.
#27
#29
I didn't say raise the front. I said put new springs and shocks in the rear. And no offense I don't understand why you would pay $$ to install fancy tubular with coil overs on the front but won't cough up $300-400 in the rear to put new leafs with a good shock in and will instead put air shocks on the car (and then in the future wonder why the car doesn't handle very well and maybe even wonder why you have to repair the floors from cracking and punch through since the shocks where never designed to carry the weigh of the car).
Running 245s on the rear of those years is a proven combo as long as you are running 17x8 with 4.75 backspacing. If you have less than that rolling the fender lips is usually required.
#30
