Hydraulic lifters easy to compress?
You should always prime an engine before the first time it's started. If for no other reason than to be sure the pump will actually make oil pressure. Maybe a gasket is bad, maybe you forgot to torque it down, maybe the pump is bad or the bypass is stuck open, galley plug got left out etc. It sucks to smoke a new engine because it had 0 oil pressure for whatever reason and it wasn't caught because no one bothered to prime it.
Thanks again for all this help.
