Spacer between carb and engine on 67 (289)
yes, I meant spacer.
Thanks
was looking at this one
http://www.summitracing.com/parts/SUM-G1404/
I have a 4 barrall (an autolite 4300 and a holley).
Doesn't look like this one has the hole.
Thanks you guys.
Thanks
Thanks you guys.
Phenolic spacers are great for preventing heat transfer from the hot engine to the fuel in the carb bowls as mentions above. Also, the added height gives you more intake plenum which can help with performance. The rub is you have to have the room under the hood. Many aftermarket intakes are tall. For instance, my Edelbrock Air Gap intake barely allows my air cleaner to clear the hood, so I cannot run a phenolic spacer.
TfcCDR
09-14-2015 12:08 PM
