Wheel adapters, new studs needed?
Old 11-09-2010, 06:58 PM
Sixty7RestoCoupe
Sixty7RestoCoupe's Avatar
Default Wheel adapters, new studs needed?
Hey everybody, just recieved my 1.5 adapters from ebay today for my 06 bullitts wheels. I know its a pretty common conversion but my concern is the stock stud length. Theres still thread on the nut but the stud isnt long enough. Is this right?
Sixty7RestoCoupe is offline
Old 11-09-2010, 10:05 PM
Iskwezm
Iskwezm's Avatar
i would try a short shank open end lug nut
Iskwezm is offline
Old 11-09-2010, 11:57 PM
guitarman376
guitarman376's Avatar
I recognized that the rear studs are not very long when I put 1.5" wheel adapters on my car. Literally checked today with a torque wrench and they haven't loosened at all. I would probably get longer wheel studs if I was going to the race track anytime soon, but my car is street driven only at the moment. The fronts were perfect for me, after doing the 13" cobra conversion that came with new hubs
guitarman376 is offline
Old 11-10-2010, 12:18 AM
TexasAxMan
TexasAxMan's Avatar
I have to say that I don't think wheel spacers are very safe at all. Judging from the pictures, you don't have enough thread left to run those safely. You should have threads protruding from the stocker lug nuts. Please don't run those ....
TexasAxMan is offline
Old 11-10-2010, 07:43 AM
ozarks06
ozarks06's Avatar
It looks like you have only about half the threads on the nuts making contact. I wouldn't use them that way (and personally wouldn't use adapters on the rear at all).
Those wheels do look nice.
ozarks06 is offline
Old 11-10-2010, 08:10 AM
kalli
kalli's Avatar
unsafe as it is. maybe with shanks. as above.
i wouldn't even use those nuts as there is no way to make sure the spacer is sitting right
contact manufacturer to provide safe solution
kalli is offline
Old 11-10-2010, 09:17 AM
Norm Peterson
Norm Peterson's Avatar
Can't see the pictures. Don't like spacers to begin with.
If you don't have thread engagement at least equal to the lug diameter, you're asking for trouble. Thread engagement equal to only half the lug diameter is like jumping up and down begging for it.
Can't tell how much thread engagement you really have? Don't drive the car until you know that you have at least one diameter's worth. This is not a place to cut corners. Replace with ARP.
That the torque has not relaxed may not be a good enough indicator that the thread engagment that you do have hasn't been yielded slightly. If that sounds like a bad thing, it sounds about right.
Norm
Norm Peterson is offline
Old 11-10-2010, 10:44 AM
5'Oclocksomewhere
5'Oclocksomewhere's Avatar
I agree with this.
If you are going to go with spacers (which I never would..) atleast do everything in your power to make sure they are bolted on correctly. Check parts stores for other length studs.
5'Oclocksomewhere is offline
Old 11-10-2010, 11:46 AM
jspagna1
jspagna1's Avatar
NOT SAFE!!!!!!
If they were 1" spacers, you would be alright but that extra 1/2" is killing you.
You are suposed to be able to get like 8 turns with the lug nut on the stud for it to be safe and I would suspect you are nowhere near that!
Call the manufacturer.
jspagna1 is offline
Old 11-10-2010, 12:03 PM
67t5ponycoupe
67t5ponycoupe's Avatar
I ran into the same problem when I was running 05 bullitts. I changed all the studs, at $2.50 a stud that adds up quick. That is the safe way to do it. With a 1/2 inch stud you should have atleast 1/2 inch of lug nut on the stud and if yours are like mine were then you will be very close to that. I don't have a problem running spacers like some fols do. I think they are safe but need to torqued properly, they are lug centic so they center themselves when torqued.
67t5ponycoupe is offline
Quick Reply: Wheel adapters, new studs needed?
