ignition ideas
+1 Mine is in an OEM distrib no problems in the past 3+ years! Much better than my old mallory distributor
I've installed it in six cylinder cars. Eliminates the need to adjust points. And the Pertronix I was intended for original, untouched engines.
ya. well spoken. the ignitor is intended to replace stock points. so the more original the better. that goes for their replacement (the ignitor module)
If you use the billet distributor from them. there are two types. One looks like a stoick distributor and uses external coil. The other looks like the one in "tcrote5516" picture. It's the HEI model where the coil is in the cap. This results in a huge cap and most aftermarket air cleaner systems (including stock) will not fit.
I think the only reason he can fit his is because of teh tall aftermarket intake manifold and maybe added spacer under air cleaner
That's somethig to keep in mind.
