Gear Vendors / Overdrive - MustangForums.com
Old 11-02-2010, 09:42 PM   #1
428 cobra jet
428 cobra jet's Avatar
Default Gear Vendors / Overdrive
Has anyone used a gear vendors overdrive unit on a B/B mustang, and what was the outcome. I have a 70 Fastback with a 427 s/o with 428 Crank, Med riser heads, Inglese intake with 4 x 48 IDA Webers running a w/r Top Loader and a Currie 3.89 rearend. Looking for a overdrive for the days I just want to crooze without all the rpm's going crazy, and I really do not want to cut or shut the car if I don't have to.
428 cobra jet is offline   Reply With Quote
Old 11-02-2010, 11:05 PM   #2
andrewmp6
Why not http://www.moderndriveline.com/catal...bb_TKO_kit.htm The problem with a gear vendors is its not a bolt in you have to make a mount to hold it and on a mustang probably have to cut or beat on the floor.I rather run a tko its a overdrive stick and will bolt right in.
andrewmp6 is offline   Reply With Quote
Old 11-03-2010, 04:37 AM   #3
derwin66
derwin66's Avatar
I thought it bolted straight on to the back of the box. I have one coming down under for my c4 and it looks pretty easy to fit. You don't have to bash the floor either it fits in just nice. The only issue is where the speedo connects to the box where it becomes a little tight which can be easily fixed if you get a speedo cable elbow with it.
derwin66 is offline   Reply With Quote
Old 11-03-2010, 04:57 AM   #4
kalli
the gearvendors website advertises that you don't need to cut tunnel etc. but if you have that thing in addition on your box I guess yoiu'll need another driveshaft?
kalli is offline   Reply With Quote
Old 11-03-2010, 10:57 AM   #5
69mach1377
69mach1377's Avatar
You can have your shaft shortened...
69mach1377 is offline   Reply With Quote
Old 11-03-2010, 10:28 PM   #6
cprstreetmachines
Fits without an extra mount or cutting. Does need a drive shaft shortened and some wiring for it's own controller. Liked it. Plan on taking a 6 spd out for a TH-400 and GV unit.
cprstreetmachines is offline   Reply With Quote
Old 11-04-2010, 02:25 AM   #7
andrewmp6
My friends 4x4 dodge we had to massage the floor a tiny bit to get it in.And from what i seen on most truck forums they burn up if you try to tow with it.
Old 11-04-2010, 12:42 PM   #8
cprstreetmachines
Really, burn up ? Huh. They aren't like a normal tranny, so that seems a bit weird, but never towed with one. They'll fit in a mustang tunnel though. The speedo cable will run the inside of the tunnel, or you can dent if you want. I really only want one to add OD to the 400. They apparently can't make the T-6060 handle more than about 1300hp reliably. Only thing I never really liked was the shifting isn't consistent enough out of the box for racing. The shift delay varies.
Old 11-05-2010, 05:20 AM   #9
andrewmp6
Over drive to a th400 is a 4l80e or a allison would hold that power.But from what i read towing you have to shift the gear vendor in neutral down hill or the stress will cause problems.
Terminated Whipple GT battles '13 GT500 on E85 Bokeo Street/Strip 6 10-10-2015 09:28 PM
Win $1500 Worth of RTR Parts - AmericanMuscle AMAlexLazarus AmericanMuscle.com 3 10-02-2015 09:06 AM
What other parts should I be concerned about if my pinion bearing went bad? KingRando 2005-2014 Mustangs 5 10-02-2015 09:06 AM
So who wins uedlose The Racers Bench 4 10-01-2015 09:31 PM
Racer Appreciation Party at the NMRA World Finals nmra1965 Other Professional Racing 0 09-26-2015 11:46 AM
2010, 400, 67th, cylinder, drive, fmx, gear, mustang, overdrive, problems, shelby, t5, vendor, vendors, wont
