Seeking 8" Posi Suggestions
#41
#42
If the 9 inch 28 spline axle rear end is no stronger than an 8 inch why would ford have made any?....I am not disagreeing that the 28 spline axles are a weak point but I do disagree that the two rear ends would fail at the same power level...The torque steer thing I think is more common with a spool type setup where one axle is locked and full power is constant regardless of what the other side is doing..
The 8" suffers from a weaker pinion support setup, because it was a smaller, lighter case. So in the 8 you might break the axles, might break the carrier guts, or you might break the 3rd member case itself. In the 9 you're not going to break the pinion support, so it's either the carrier guts or axles.
That's why if you look at most of the 9" rears that grenade, they're usually 28s differential type units, and they break axles or the carrier guts.
Now, a 31s 9" rear with an upgunned carrier is substantially stronger than an 8". If you ran an 8" with a stock 3rd case, but forged axles and a heavy carrier unit....launch it on slicks and it's almost a guarantee you'll spit the pinion gear right out the front of the case. Especially with a heavy clutch.
folivier
Tennessee Regional Chapter
10-02-2015 05:32 AM
