Thought on front suspension
hey ez what are your springs ect, i like the stance of it, im gettin ready to order the uppers and perches and the front srpings, and what is your tire size also because if i go with the mid eye 1 inch drop id have to drop from my 245 45 r 17 rear tire is the thinking, sorry for highjacking your thread lol
hmm check these out. build your own roller uppers. then attach coil over to lower control arm
http://www.ubmachine.com/upperheimjoint.html
I just got off the phone with UB machine. They manufacture uppers and lowers for dirt track racers. Ill be able to make thier uca and lca full rollers. UCA are open and shock will bolt directly to lowers! SWEET!
So far this is what I have come up with if im going to design one like TCP
2 uca and 2 lca from UB machine ~$160
4 screw in ball joints @ $20 ea. $80 screw in vs bolt in ?
4 5/8 heims @ 10. ez $40
johnny joint for lower control arm $55
Fabricate mounts for upper shock - $10 six pack
Fabricate or purchase inner shaft $25
QA1 coilovers what length to attach to lca? $350
probably about 3 12packs of coronas $60
So total would be just a bit over $700 to make a design just like TCP
It would basically look like this kit
http://www.stangnet.com/mustang-foru...rformance.html
who cares how clean it looks...im not going to take my wheel off and go look how pretty that aluminum piece is that you cant see. thats part of what makes that setup over priced.
Actually I could Mount a shock mount on the stock LCA and use it
Gconnsr- I agree I like using the small block. One advantage the 65-66 have is the light weight. 2800lbs and 400+hp is a lot of fun
after looking at stock LCA the sway bar mount would be in the way
http://3.bp.blogspot.com/_UK4NtnA-b7...0-h/MU+425.jpg
