Homebuilt coilover system - Page 17 - MustangForums.com
Old 01-07-2012, 07:05 PM   #161
Norm Peterson
Norm Peterson's Avatar
Best I can do.
The thick red line is the shock/spring with top and bottom pivot axes as shown. Extending that line needs to hit the centerline of the heavier "leg" as shown to avoid trying to bend the lighter-weight leg. As also mentioned, the sta-bar attachment needs to be arranged in similar fashion.
I hope buening doesn't mind me doing a grafitti job on his picture, but I'm not nearly good enough at CAD or even the computerized drafting available in MS Word/Excel to even think of putting something like this together from scratch.
Norm
Norm Peterson is offline   Reply With Quote
Old 01-09-2012, 04:17 PM   #162
pappakeeno
Quote:
Originally Posted by eZ View Post
Buening...Hey man glad your giving it a go. I can post a pic for you when I get back from the gym. The motor is out of my car right now....it went kaboom. So the suspension is at full hang right now wich will give you a good idea. As far as the johnny joints I remember ther ebeing a problem with them size etc. I still have 2 johnny joints sitting in my tool box. I do know their advertised measurements were wrong. Im sure they fixed that problem.
Magnus. Let me see if I can find the drawings and have some made for you. either way I can get it done.
That would be great if you could do it for me. I`m going to use the same Proma springs and since you are so satisfied with the handling of the car, I think itīs best to have your brackets.
I have started my winter project with adjustable strut rod and spherical bearings in the LCA.
DIY saves a hole lot`s of money, if I buy the TCP front end for 2600$ the price when I recive it in Sweden would be 3700$ ,so thats not an option;-)
The car I have is a 66 coupe with a 408 and a t5 bought from California in 2006, restored and painted last year in Limegold metalic.
/Magnus
pappakeeno is offline   Reply With Quote
Old 01-31-2013, 01:59 PM   #163
tweet66
upper mount has a 1 inch aluminum spacer. The shock mount is 2 inches from plate to center of eyelet. plate is 1/8 inch thick. so total distance is 3 1/8 for upper mounted underneath shock tower.
lower mount is also two inches from plate to center of eyelet plus 1/8 plate
Okay in a effort to bring a thread back from the dead... and due to too many life/money issues creeping up, I'm finally (I think) ready to try this out. I have a question though. I was looking through Summits site and noticed QA1 DS601 which are about 1.75" longer (extended), 0.875" longer (compressed) and was wondering if I could use those and eliminate the 1" aluminum spacer up top? Any thoughts?
tweet66 is offline   Reply With Quote
Old 01-31-2013, 09:20 PM   #164
jgemperline
jgemperline's Avatar
I think that spacer allows installation without removing the original spring mount. I could be wrong but that's my observation. If that's all it's for than all you need to do is drill out the old spring mount. I just finished one spacer for a similar build. I bought a 1" length of thick walled aluminum pipe. I did use a lathe to take a bit off the inside. Seemd to work. It's exiting to see another effort. Good luck. Keep us posted.
jgemperline is offline   Reply With Quote
Old 02-01-2013, 10:31 AM   #165
jgemperline
After a good night’s sleep. I realized that this will change your angle of shock. Im still researching but 20-25 degrees comes to mind. I don’t know what this will do to the performance but worth looking into. May need to lengthen that mount point if you don’t use the spacer. I will wait to see what others say.
Old 02-01-2013, 12:06 PM   #166
tweet66
I had thought about shock angle and figured I could move the upper mount towards the tower. 20 deg is the number I've seen for shock angle. Not sure how much say 18 deg. would affect the motion ratio or change the coil pressure I intend to use.
Old 03-09-2014, 05:37 PM   #167
Cali_Screw
Cali_Screw's Avatar
Bumping up a old thread, Just curios to see if there was anyone else that did this? I will be attempting this soon myself but with a few other approaches to it..
Cali_Screw is offline   Reply With Quote
Old 04-01-2014, 09:55 PM   #168
jgemperline
Not yet. I hope to order the uca for my 68 soon. Need get dimensions to have them specially built by ub machine. First need to finish some body work. Cali_screw do you plan to share your build?
Old 04-01-2014, 10:45 PM   #169
rwcstang
very nice
rwcstang is offline   Reply With Quote
Old 11-15-2014, 11:52 PM   #170
eZ
eZ's Avatar
Default Still running
Well its been a long time but the suspension is still great. I went back in and use locktite on everything so nothing will giggle loose. I've had to build another motor but car is still great. I've channeled the exhaust a bit so I can really slam the car if I want to now with the front and rear being adjustable.
eZ is offline   Reply With Quote
Vintage AC shop referral - frontrunner serpentine system bradleyb Classic Mustangs (Tech) 3 11-27-2015 08:50 PM
04 Mach 460 system, Installed Aftermarket HU, No Highs/Tweeters breaking Audio/Visual Electronics 5 10-02-2015 02:27 PM
Hot Lap: 2015 Roush RS3 Test + Build a Supercharger! - AmericanMuscle.com AMAlexLazarus AmericanMuscle.com 0 10-01-2015 10:21 AM
Vintage AC shop referral in los angeles bradleyb California Regional Chapter 0 10-01-2015 02:02 AM
Please help! 10 Check engine codes mrtrodonet V6 (1994-2004) Mustangs 1 09-29-2015 12:13 PM
1967, arms, built, coil, coilover, control, diy, home, homebuilt, homemade, james, lca, link, musnicki, mustang, roller, system
