Homebuilt coilover system - Page 3 - MustangForums.com
Old 01-15-2011, 05:40 PM   #21
musnicki
musnicki's Avatar
I'm trolling this topic as well. Keep us posted, more pictures.
Amazing work btw.
The link below goes to my facebook where I have some pictures of my front coils if you need some refrences. Let me know if you need me to take pictures of any particular area. I'm humbled by your work, I paid an arm and leg for mine.
James
musnicki is offline   Reply With Quote
Old 01-15-2011, 07:15 PM   #22
eZ
eZ's Avatar
James/musnicki
Your link just brings me to facebook.com. It does not bring me to your page.
I got my shocks in yesterday and mocked them up. Ill try to do some welding this weekend and Im still waiting for the chromoly hex bar to show up for my UCA. Other than that I should be able to bolt it all up this week. Ill post detailed pics when I do the final installation. After that Ill try and break something by driving the bejesus out of it!
eZ is offline   Reply With Quote
Old 01-15-2011, 11:27 PM   #23
F15Falcon
Quote:
Originally Posted by Gregski View Post
So you're using MIG and not TIG?
There is no strength advantage to using TIG over MIG.
F15Falcon is offline   Reply With Quote
Old 01-15-2011, 11:51 PM   #24
F15Falcon
Quote:
Originally Posted by eZ View Post
I did consider this intially but if you look at the design of the original LCA it is not a straight line. Also How would you attach the sway bar to the afco? also the ball joint would set at the wrong angle on the afco, probably run into a binding issue. Just seemed really easy to make a bolt on mount.
These are a couple of pics of the tubular lower control arms I build for Mustangs and Falcons. Very similar to the AFCO units but I use 1 1/4" x .120" wall round tubing. For applications with a sway bar, I slug right through the tubing with a piece of 1/2" O.D. tubing to bolt the sway bar end link to. I also incorporate an adjustable strut rod as well:
Old 01-16-2011, 12:36 AM   #25
eZ
eZ's Avatar
F15- Nice simple design on that strut rod. I was lazier and drilled a hole through the frame rail. I wanted to do it this way so that it would not shorten the arc of the strut rod. Im going to do away with the misalignment spacers and do a solid spacer all the way accross.
Uploaded with ImageShack.us
Old 01-16-2011, 10:34 AM   #26
Norm Peterson
Norm Peterson's Avatar
. . . why do we pay upwards of $500 for tubular control arms while circle track and offroad guys pay about $100?.
Because most people don't look outside sources that say "Mustang" or "Ford" or the various sponsors of this and other Mustang forums. Good to see some out of the box thinking and DIY fabrication going on here.
Looking at sources like circle track racing supply houses is frequently a good, solid option, but I think you do have to be looking at your project more like the old-time hotrodders did than like the new breed of "checkbook car builders" seem to.
Sometimes, you might even have to consider modifying the part before installing it, or figuring out what else has to be changed. That's a problem for some folks.
(That said, the use of circle track upper arms is somewhat more widely known over on the boards that cater to the 1978 - 1987 GM intermediates; don't know why it seems to be such a secret here.)
Norm
Norm Peterson is offline   Reply With Quote
Old 01-18-2011, 06:07 PM   #27
eZ
eZ's Avatar
A little update...
Finished welding and boxing in the upper and lower mount. Turned out really well. No binding throughout the suspension travel. Im finishing up the upper control arm mount then that should be it!
This is just mock up before I finish all the parts. Need to paint. and buy the right size bolts etc.
Old 01-18-2011, 06:33 PM   #28
F15Falcon
Nice job, that will work great.
Old 01-18-2011, 07:19 PM   #29
eZ
eZ's Avatar
F15--I have a setup that bolts directly to the stock mounting points. Its a coilover Tbar setup. It would work great with your setup
Old 01-19-2011, 09:08 AM   #30
482supersnake
who did you get your upper control arm from? Looks great and nice welds. Scott
482supersnake is offline   Reply With Quote
Vintage AC shop referral - frontrunner serpentine system bradleyb Classic Mustangs (Tech) 3 11-27-2015 07:50 PM
04 Mach 460 system, Installed Aftermarket HU, No Highs/Tweeters breaking Audio/Visual Electronics 5 10-02-2015 01:27 PM
Hot Lap: 2015 Roush RS3 Test + Build a Supercharger! - AmericanMuscle.com AMAlexLazarus AmericanMuscle.com 0 10-01-2015 09:21 AM
Vintage AC shop referral in los angeles bradleyb California Regional Chapter 0 10-01-2015 01:02 AM
Please help! 10 Check engine codes mrtrodonet V6 (1994-2004) Mustangs 1 09-29-2015 11:13 AM
1967, arms, built, coil, coilover, control, diy, home, homebuilt, homemade, james, lca, link, musnicki, mustang, roller, system
