Accurate oil pressure gauge mustang dash
Old 01-20-2011, 11:20 PM
001mustang
001mustang's Avatar
Default Accurate oil pressure gauge mustang dash
Would like to rig VDO oil psi gauge in 67 dash.
Is that a reasonable project?
Been done before?
What does VDO guts look like?
Attached Thumbnails Accurate oil pressure gauge mustang dash-0-0609101043.jpg   Accurate oil pressure gauge mustang dash-0-0912081731.jpg   Accurate oil pressure gauge mustang dash-0-dsc_7892.jpg   Accurate oil pressure gauge mustang dash-0-vdo-350104d-vision.jpg
001mustang is offline
Old 01-21-2011, 03:22 PM
Jonk67
Jonk67's Avatar
Can be done, I think it takes some cutting to the back of the dash as there is plastic in the way for a non original gauge (they're not round) and you need to measure to see if 2 1/16" or 2 5/8" will be closer to the size you need.
I installed a Sun Tach in a 5sp blazer years ago, cut the bezel off the gauge, removed the glass and flush mounted the gauge into the dash cluster from behind so the cluster hole was smaller than the gauge face. Looked almost stock. Might be an idea to look at. I've also seen people mount them from the front and leave the gauge intact, then made a bracket to pull it against the cluster face from behind.
Jon
Jonk67 is offline
Old 01-21-2011, 09:25 PM
001mustang
001mustang's Avatar
The VDO gauge has 2 screws on the face. I'm thinking I will have to drill 2 holes in OEM face for the 2 VDO screws. Not a fan of drilling in OEM but I do have a spare OEM gauge face plate.
I will try your idea of securing from behind first.
Possibly only 20psi to 60psi lettering will be visable. I can live w/ that.
Old 01-22-2011, 02:51 PM
Jonk67
Jonk67's Avatar
Just looked at your second pic, didn't realize the stock oil pressure gauge comes out by itself leaving the face. If I'm looking at it correctly your VDO 20-60 is going to be upside down?
Edit, nevermind, guess it will be right side up, hard to wrap my head aroud it with the pic of the original face upside down in the pic and the VDO gauge right side up....
Jon
Jonk67 is offline
mstahoo
SVT Forums
08-19-2021 09:15 PM
yurizx6r
09-07-2015 06:40 PM
jjwinel78
08-17-2015 03:34 PM
daytooday
08-11-2015 09:22 AM
yurizx6r
08-11-2015 07:50 AM
Quick Reply: Accurate oil pressure gauge mustang dash
