1969 302 max Bore?
1969 302 max Bore?
I have a 1969 block that needs to be bored over to .060 but my local machine shop says I should get a different block. Now I've heard that the 1969 blocks have thicker cylinder walls and was wondering if the 1969 block can handle running with a 0.060 with little to no issues? I've heard that if they do have issues its usually cooling.
Even if you don't have a core shift problem, .060 will allow so much heat to get through the cylinder wall you'll have trouble keeping it cool. If this is something special, see if they can sleeve it. If not, replace it.
Galactic
04-29-2019 02:56 PM
bradleyb
11-27-2015 07:50 PM
jaiidutch
09-14-2015 10:29 AM
