MustangFTW 67 resto thread.
#61
Guest
Posts: n/a
pics up soon, i used degreaser to clean them then sanded to make the surface a bit rough, then sprayed. holy hell the left one (if your infront of the car) is hard to get off and on with all the tubes and wires going across.
#66
Guest
Posts: n/a
ok now something weird happened today, i was trying to set my fast idle so once i finished i took my car for a spin around the block, when i got back i noticed something that resembled exhaust coming from under the hood, so i opened up the hood and it seemed to be coming from the far left corner near where the exhaust manifold meets the exhaust pipes, could've been coming from behind but i couldn't tell clearly. this is the first time this happened.
i also noticed oil that seemed to seep between my carb and the intake manifold, never seen it like this. Could i have done something when i removed the valve cover a few days ago?
#67
Guest
Posts: n/a
is the correct term intake manifold or spacer for the piece with 2 holes cut in it?
edit: i also spilled quite a bit of the liquid in the red tubes that go from firewall to engine black, is this coolant? it spilled all over the block.
Edit again: i took a closer look seemed like some oil had leaked out from the valve cover, i tried tightening the valve cover bolts they were kind of loose, once i tightened them i wiped off oil and will check tomorrow to see if it still leaks, if it does ill take off cover and chec kto make sure the gasket is seated correctly.
#68
Guest
Posts: n/a
