rear window problems in coupe 67
I have a 67 coupe and the small rear windows don't go up and down that easily I was wondering if there are any rebuild kits made to fix this? also the locks in the front
RE: rear window problems in coupe 67
ORIGINAL: guitarist88
I don't exactly know what the regulators are. how hard are they to replace?
It is not hard job, but it will take some time when you do it first time.
Take off the handle first. Then take all the retaining screws off the cover, and pop it off carefully. You will see some heavy brown paper that is the rain guard. That that off carefully so you can use it again. Once you get that off, you will see the plastic rollers on the guide. Spray those plastic rollers with WD-40, then try to get as much of the old grease out of the guide as possible. Use some fresh grease to lubricate the plastic rollers and put some on the inside rails of the guide as well. A lot of Techs suggest using white lithium grease, but I prefer just plain old bearing grease. Lithium tewnds to dry out over a period of years. Also, apply a hefty amount of grease to the gears on the regulator. Put it all back together, and walaaahhhh. The window will roll up and down with ease. Now, this is assuming the plastic rollers are not damaged. If they are, you will need to replace those. Ford used steel rollers in the 50's and they never wore out. It is not very often that the regulator goes south, but if it is, then you will need to replace that as well.
Soaring, I am having a similar problem on my 66 convertible. The window will roll down part way and then "fall off" whatever it is attached to so that it just falls down. If it goes all the way down it is tuff to get ito ut as when I turn the handle nothing happens. If I do manage to pull it up tot he top and roll the handle all the way, the window stays up?
It seems odd that I could acess the entire mechanism simply by removing the handle (if I understand you correctly thats what you tolf guiterist88).
anyways, any help would be much appreciated.
Zenon
Zenon
The glass part of the window is glued into a rail. Apparently, the glue on yours has given way, so you need to get that glued again. I am not sure which brand of window to guide glue to get. But, I assume there is a special one. Do some research. If, after you get in there and see that the glass is still securely glued to its rail, then the plastic roller may have slipped out of its guide. Just take a good look at what is wrong after you get the cover off. It's really a pretty simple mechanism, and common sense will guide you in how to fix it.
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
carid
08-25-2015 08:17 AM
