WAAHOOOO
Old 02-12-2011, 10:40 PM
mortman
mortman's Avatar
Default WAAHOOOO
After 3 years i finally made the t-5 swap. The adaper plate was MUCH easier that i thought it as going to be. Fired up the car an spun through all the gears (on stands), FLAWLESS!
Button up a few things tomorrow and take her for a spin...
Question... The T5 Manual states to use ATF! Is this correct or should i use gear oil?
mortman is offline
Old 02-12-2011, 10:47 PM
Gun Jam
Moderator
Gun Jam's Avatar
yes
Use atf...I think dex III or merc V...you'll want to double check and this assumes that its an 83 to 93 t5 (which I think all use atf) I hear some older t5s used gear oil...
I think most of the above is mostly correct
-Gun
Gun Jam is offline
Old 02-12-2011, 10:52 PM
mortman
mortman's Avatar
Thank you Gun. just not used to ATF in a manual
mortman is offline
Old 02-12-2011, 11:13 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
world class t5s use ATF if you use gear oil you will urn up the needle bearings in the the tranny with a quickness
most people use synthetic synchromesh from GM....
rmodel65 is offline
Old 02-12-2011, 11:42 PM
1slow67
ROTM Moderator
1slow67's Avatar
I use valvoline dex/mercov in my WC
1slow67 is offline
Old 02-13-2011, 12:39 AM
mortman
mortman's Avatar
BA thats exactly what I put in. Now i just need to find out where all the smoke is coming from, I am prying its just grease oil and penetrating fluid burning off the exhaust. I only ran it for about 5 minuets today
mortman is offline
Old 02-13-2011, 01:25 AM
boogerschnot
boogerschnot's Avatar
Probably so.. my aod smoked like a train for a few minutes after warmup due to all the greasy finger marks everywhere.
boogerschnot is offline
Old 02-13-2011, 04:59 PM
musnicki
musnicki's Avatar
Fun fun fun. One of my best upgrades for my car was putting in a 5 speed right behind the coil over suspension.
Going 80mph on I-95 at 4k rpms vs going 80mph on I-95 at 2.5k rpms......
musnicki is offline
Old 02-13-2011, 06:18 PM
tcrote5516
tcrote5516's Avatar
I agree, not that most of us care but getting decent hwy gas mileage is another nice benefit from the swap.
tcrote5516 is offline
Old 02-13-2011, 07:20 PM
putz54143
putz54143's Avatar
cant wait to do mine, i am doing t5 and 347 same time. engine is at the machine shop now. i have the pedals and linkage, now still lookin for trans.
putz54143 is offline
