questions
Old 02-17-2011, 01:39 PM
mortman
mortman's Avatar
Default questions
I replaced my 3 speed trany with a T5 last weekend. Yep issues. I did not replace the clutch ect as I should have. So I am replacing the clutch, pressure plate and throw out bearing this weekend.
2 questions:
1. Do I need a special puller to replace the shaft bearing?
2. I have a loose exhaust (off the manifold) and need to tighten it, squirted with penetrating fluid and let it soak in, still wont budge! I have yet to try using an impact wrench because I don’t want the bolt to break.
Thanks
mortman is offline
Old 02-17-2011, 02:06 PM
boeing747arowair
boeing747arowair's Avatar
There are special pullers to remove the pilot bearing. Most people pack the bearing with grease and insert a shaft the size of the bearing hit it with a hammer and the grease serves as a hydralic and pushes the bearing out
boeing747arowair is offline
Old 02-17-2011, 04:54 PM
scootchu
scootchu's Avatar
You can use tissue, toilet paper or regular paper. Watch this:
http://www.youtube.com/watch?v=1xuR7T8G1Ys
I got mine out this way.
scootchu is offline
Old 02-17-2011, 04:59 PM
boeing747arowair
++++1!
Old 02-17-2011, 07:24 PM
Starfury
Starfury's Avatar
On the exhaust, use a torch. Mapp gas or oxy/acetylene would be good, but propane might work. Hit it again with penetrating fluid (PB Blaster or Aero Kroil; WD-40 is NOT a penetrating fluid), let it soak in a bit, then heat it up. It should break loose then.
Starfury is offline
Old 02-18-2011, 08:07 AM
boeing747arowair
Aero Kroil and PB Blaster are the best best best penetrating fluids ive seen. WD-40 is the worse thing ever created no wonder it tooks 40 times to create that crap!
Old 02-18-2011, 09:24 AM
kalli
kalli's Avatar
i used the grease method. worked fine. the paper version seems to do the same, i'd just be too lazy for that ...
kalli is offline
Old 02-18-2011, 09:56 AM
scootchu
scootchu's Avatar
I'd rather keep myself and the surrounding area free from grease.
scootchu is offline
Old 02-18-2011, 09:53 PM
mortman
mortman's Avatar
Thanks Scoochu, i must give that a shot. too cold to do it this weekend
mortman is offline
Old 02-19-2011, 06:10 AM
kalli
kalli's Avatar
ya, i was always something of a messy mechanic. something in my head if the place around me doesn't look like utter crap then no proper work is done :-)
kalli is offline
Dokilar
15
10-16-2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
Quick Reply: questions
