new valve spring question
Old 02-21-2011, 01:34 PM
mr_velocity
mr_velocity's Avatar
Originally Posted by ColtonS3290
But no one knows what the smaller spring is for?
Sounds like you didn't get what you ordered. It sounds like you got dual springs when the part you ordered is a single spring. Call Comp.
mr_velocity is offline
Old 02-21-2011, 02:51 PM
67mustang302
67mustang302's Avatar
Did you order specific springs for a specific cam?
67mustang302 is offline
Old 02-22-2011, 02:46 AM
ColtonS3290
ColtonS3290's Avatar
I had a guy I use order a rebuild kit using specs from cam, crank, etc. they should be right ones, guy is pretty reliable, but I'm gonna double check to be sir.
ColtonS3290 is offline
Old 02-22-2011, 11:42 AM
001mustang
001mustang's Avatar
inner spring is common on roller lifters and aggressive flat tappets to make sure valves don't get ADD.
do u have roller?
001mustang is offline
Old 02-22-2011, 12:20 PM
mr_velocity
do u have roller?
Bad case of ADD.
Single Outer Valve Spring O.D. 1.437", I.D. 1.039", Seat load 115lbs 1.700", Open load 284lbs 1.200", Coil bind 1.125", Rate 339lbs/in, With damper
Old 02-22-2011, 12:31 PM
001mustang
001mustang's Avatar
lol.
not the worst thing to have a bad case of...
Old 02-23-2011, 03:45 AM
ColtonS3290
Its not roller cam, but got roller rockers.
Old 02-23-2011, 02:06 PM
001mustang
001mustang's Avatar
Make sure you don't use inner spring while breaking in a flat tappet cam.
Don't use good headers while doing flat tappet break in.
Old 02-23-2011, 03:56 PM
mr_velocity
Don't use them at all until you figure out what they are. 942-16 is what he said they were, these are not dual springs.
Old 02-24-2011, 10:08 PM
ColtonS3290
Thank you all for your advice, but i have gotten the part number wrong on the springs, the comp springs part # is 927-16 and my Comp Cam camshaft # is 31-414-3, are these two compatible with each other, i know it says that the springs aren't recommended with the cam on compcams but can i still use them?
Quick Reply: new valve spring question
