Springs ??
Old 02-25-2011, 05:20 AM
wonso79
wonso79's Avatar
Question Springs ??
Hi,
I am re-doing my suspension and already bought my KYB shocks. Now it's time to pick out my new coil and leaf springs. I am thinking about buying them with a 1" drop. I have a Inline 6 and just wondering if anyone thinks it's worth spending extra $$ or should I just go with stock stuff. I am eventually going to put the American Racing Wheels (Ansen Sprint) 15x7 on the car to give it a better look. Ideas, thoughts, concerns?
wonso79 is offline
Old 02-25-2011, 05:30 AM
2+2GT
2+2GT's Avatar
Glazier/Nolan will sell you show-correct GT leaf springs, with eye and U bolts, and shackles, for under $200. They have similar deals on other items. This car is wearing their suspension pars. Seems like a good stance to me:
2+2GT is offline
Old 02-25-2011, 08:37 AM
Starfury
Starfury's Avatar
A little high for my tastes, but you could always cut down the fronts a hair if you don't like it. I have Mustangs Plus 1" drop 560lb coils in the front of my car, but I think they'd be too stiff for an I6 car.
Starfury is offline
Old 02-25-2011, 09:36 AM
1slow67
ROTM Moderator
1slow67's Avatar
Yeah the 1" drop coils made mine look like a 4x4 with a 2" lift kit. I had to cut the coils to get it to look right.
1slow67 is offline
Old 02-25-2011, 10:31 AM
wonso79
wonso79's Avatar
So your all thinking I should just stick with the stock Inline6 replacements?
wonso79 is offline
Old 02-25-2011, 11:46 AM
2+2GT
2+2GT's Avatar
The 64-66 200 and regular 289 use the same springs, since the engines are very similar in weight. The 65-66 GT uses a heavier spring. Either way, you should follow the link below and do that when you install the new springs. The front will be slightly lowered, and you can work from there if you need to take out 1/4 coil, etc, to fine-tune.
Arning/Shelby Suspension Drop
2+2GT is offline
Old 02-25-2011, 07:22 PM
Jonk67
Jonk67's Avatar
If you don't want as 'high' a stance as the GT350 above i would look at 480 1" drop springs. Just remember if you go with standard springs and they're too high by much they will get stiffer every time you cut more of the coil off.
Jon
Jonk67 is offline
Old 02-25-2011, 10:41 PM
1slow67
ROTM Moderator
1slow67's Avatar
What size tire would you put on the 15x7s?
1slow67 is offline
Old 02-25-2011, 11:53 PM
onesweet02
onesweet02's Avatar
I cut one coil off the front of my 69... it lowered her 2".& on the back i installed 1.5" lowering block. Just check out my pic of my 69...
onesweet02 is offline
Old 02-26-2011, 05:34 AM
wonso79
wonso79's Avatar
Haven't really thought about it, probably something around the stock size
wonso79 is offline
Quick Reply: Springs ??
