351W or 302 Stroker in a 1965 Mustang
#81
First year for rollers in 302's was 1985 iirc. Generally most all the factory production engines went to rollers in the midish 80's. Even many modern OHC setups are using hydraulic lifters(or lash adjusters of some sort) with roller followers. So "hydraulic roller" of some sort has become pretty much standard since the 80's.
#82
I'll let you in on a couple of secrets.
Although I've never gotten very far away from tinkering with cars, I've had to learn a few things (or re-learn the same things) just about every time I've taken on a project. And it'll be the same the next time. As far as I'm concerned, the research and the learning is just another part of the job. Sometimes, just clearly defining what you want out of it all is the tough part. After that, the wrenching is the easy part (or at least it used to be).
I hear you on the implications of the passage of time . . .
Norm
Norm
