Starting engine that hasn't been run in 10+ years
Old 03-22-2011, 08:02 AM
TexasAxMan
TexasAxMan's Avatar
Yes, attach a fuel hose to the inlet on the fuel pump on the engine and run it into a 5 gallon gas can. This will eliminate the fuel tank and lines as they are likely corroded, mine sure as heck were.
All fuel system parts are available from a number of Mustang suppliers.
TexasAxMan is offline
Old 03-22-2011, 12:52 PM
bluemustang1966
bluemustang1966's Avatar
Ok. So I've got my carb cleaned up and rebuilt. I'm going to change the oil when I get home. I know you have to said to prime it first, but after removing the distributor, how do I prime it? Not to sound to dumb, but this is new to me. Thanks as always.
bluemustang1966 is offline
Old 03-22-2011, 01:58 PM
TexasAxMan
TexasAxMan's Avatar
You take a socket that fits the oil pump drive (sorry, can't remember what size) on the end of an extension and using a drill (turning counter-clockwise) run it until you see oil coming out of the pushrods for all cylinders, which means the valve covers need to come off too. MAKE SURE YOU SECURE THE SOCKET TO THE EXTENSION, with electrical tape or similar.
Old 03-22-2011, 02:35 PM
bluemustang1966
Not to sound to ignorant, but is the oil pump part of the belt assembly on front of engine? I haven't look really close yet to find the whats what, but if I can save some time identifying I'd appreciate it.
Old 03-22-2011, 02:37 PM
boeing747arowair
boeing747arowair's Avatar
oil pump is located in the oil pan it is not visible
boeing747arowair is offline
Old 03-22-2011, 02:42 PM
bluemustang1966
So I have to remove the oil pan to do this, or is the pump attached externally, ie belt driven?
Old 03-22-2011, 02:59 PM
boeing747arowair
no and no. As said prior on this thread, you remove the dizzy, and with a drill inserted you prime the oil system
Old 03-22-2011, 03:11 PM
imcaracer84
imcaracer84's Avatar
The before referred to dizzy is the distributor. Pull it out and insert the socket through the distributor hole.
imcaracer84 is offline
Old 03-22-2011, 06:03 PM
bluemustang1966
Thank you. I was just about to ask what a dizzy was. Makes sense now. Thanks again. Will try soon.
Old 03-22-2011, 08:16 PM
TexasAxMan
TexasAxMan's Avatar
When you remove the distributor, take a flashlight and look down the hole. You should see a shaft with a hex head on the top. Again, make sure you tape the socket to the extension so it doesn't fall off when you're done and remove it, or else you will have to remove the oil pan and maybe the pump.
The oil pump is what turns the distributor, so when you take the "dizzy" out, you can make sure you have the correct size socket by comparing it to the hex shaped hole on the bottom of the distributor shaft. Once you see it, it should make sense.
PM me if you need further information.
djbigskrilla
09-20-2022 01:04 AM
msavoia23
12
07-07-2018 12:08 PM
KEM Motorworks
08-14-2015 10:13 PM
Pain.
08-07-2015 10:48 PM
Quick Reply: Starting engine that hasn't been run in 10+ years
