Dropping the distributor the Ford way v. Chevy way. - Page 2 - MustangForums.com
Old 03-15-2011, 12:09 PM   #11
kalli
15426378: like 2+2 said 7 and 8 wires seperated as far as possible. they fire after each other and the cylinders are next door neighbours
13726548: 5 and 6 wires seperate for the same reason
kalli is offline   Reply With Quote
Old 03-15-2011, 12:14 PM   #12
TexasAxMan
18436572 in a GM is the same as 15426378 in a Ford, if you number the cylinders the same way. I've had 18436572 in my head since my teens (a long time ago) and still use it to wire a Ford. At least this holds true for 289/302, I know some engines have different firing orders, just too lazy to look it up.
TexasAxMan is offline   Reply With Quote
Old 03-15-2011, 01:30 PM   #13
buening
ah crap, I had my head up my rear. I thought that firing order looked a little off but was too lazy to look it up.
buening is offline   Reply With Quote
Outer shock tower braces guitarman376 Classic Mustangs (Tech) 6 10-11-2015 01:47 AM
84 mustang rearend brake fittings 67LimeCoupe 5.0L (1979-1995) Mustang 9 09-21-2015 06:34 PM
New member and just bought my first mustang Luke9222 New Member Area 7 09-04-2015 06:46 AM
Putting a 2015 Mustang GT on a diet. panic 5.0L GT S550 Tech 7 08-28-2015 02:37 AM
New member from Cali Tyoung68 New Member Area 7 08-25-2015 04:31 AM
1967, 302, 50, distributor, distrubor, droping, dropping, ford, gm, motor, mustang, rotate, rotor, trick, turns
