71 4 speed car questions
Old 03-18-2011, 07:36 PM
BlackRat
BlackRat's Avatar
Default 71 4 speed car questions
-How difficult is it to convert an automatic to a manual transmission?
-If I put a 429 in a 71 instead of a 351 are the linkage mounting points and overall setup different?
Someome told me it was a whole lot different and much harder to install a 429 with a 4 speed than a 351. He said that some of the parts are not even reproduced for the linkage.
BlackRat is offline
Old 03-18-2011, 07:58 PM
2+2GT
2+2GT's Avatar
Some of the 351 4-speed parts are reproduced. Neither equalizer is, though.
2+2GT is offline
Old 03-18-2011, 08:16 PM
BlackRat
BlackRat's Avatar
What is an equalizer??????
BlackRat is offline
Old 03-19-2011, 11:02 AM
2+2GT
2+2GT's Avatar
That's the real name of the "Z-bar".
The 71-73 clutch parts I know are reproduced are the clutch pedal, assist spring, upper clutch rod, upper clutch rod firewall seal, engine-mounted equalizer pivot, inner and outer equalizer bushings, and lower clutch rod.
The pivot on the list is the 351 item. I don't know if any of the other parts also work for the 429. Certainly the pedal, seal, spring, and firewall seal, but the rest, only maybe.
2+2GT is offline
Old 03-19-2011, 02:30 PM
1971mach1
1971mach1's Avatar
I went from from C6 auto to manual (professionally done, I wanted it done right and don't have the proper
equipment or time). If you're a good mechanic and have a way to swap the tranny, it doesn't look that hard. The C6 and FMX auto trannys are heavy, about 200lbs.
If you're going that far though, why not put in a 5-speed? A good toploader costs about the same as a heavy-duty 5-speed. You will need a different driveshaft. Also why bother with Z-bar?, just use a new cable clutch kit. They make one to fit a 71, goto moderndriveline.com for more info and parts.
Can't help with the 429 (i know at least you'll need heavier springs), but again why bother?
You can stroke a 351C to 408ci and it will be much lighter than a 429. Even a stock 351 can have plenty of power with headers, carb, intake and the right gears.
1971mach1 is offline
Old 03-19-2011, 08:14 PM
TexasAxMan
TexasAxMan's Avatar
With cable and hydraulic setups available, anything is possible. Even in your driveway. Do some research, call some vendors, buy some parts and git-r-done.
TexasAxMan is offline
Old 03-19-2011, 09:46 PM
andrewmp6
andrewmp6's Avatar
Price a big block top loader tho they ain't cheap i would look more in to a tko.
andrewmp6 is offline
djbigskrilla
09-20-2022 01:04 AM
ShaneB26154
35
03-04-2021 04:05 AM
algregory
09-06-2015 05:52 PM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
Quick Reply: 71 4 speed car questions
