Help with Carb setup
Old 04-14-2011, 07:06 PM
jp1967stang
jp1967stang's Avatar
if you have an air compressor then take the fuel line off behind the pump and blow it out, dont forget to remove the gas cap.
jp1967stang is offline
Old 04-15-2011, 08:21 AM
boeing747arowair
boeing747arowair's Avatar
how bout removing the rubber on the line from the line to the tank. so when you blow it, if anything is in the line it wont go back in the tank?
boeing747arowair is offline
Old 04-15-2011, 09:35 PM
Delman2000
Delman2000's Avatar
Default Carburettor Set Up
I have a 1966 Mustang 289
Does anyone know whether the choke plate should be vertical or horizontal when the engine is warm and the car is running. Mine is in the horizontal position when warm but my car is running ok when I'm accelerating but if I ease off the accelerator it is jerking.Trying to hold it at a constant speed it won't run smoothly but when I'm accelerating its fine. I've tried adjusting the choke plate when the car is stationary but when I throttle it up by hand the plate instantly goes back from vertical to horizontal position.
I think it might be something to do with the automatic choke but don't know how it works can anyone help.
Delman2000 is offline
Old 04-19-2011, 10:08 AM
maestro1024
maestro1024's Avatar
Got out on the car yesterday and worked out this some.
cleaned out the front of the carb and tweaked mixture a bit.
I think that helped a lot.
Also tried running hose from some of the extra holes on the side and that did not appear to make a difference for good or bad.
After cleaning it out, I was able to go up the road. One problem I have still is, if you really pop the pedal hard. The engine sounds like it wants to cut off for a second.
I think I may pick up a new carb later anyway but I don't understand why it wants to cut off when you really hit the pedal hard. Works find if you work up to high acceleration.
maestro1024 is offline
Old 04-19-2011, 10:55 AM
Norm Peterson
Norm Peterson's Avatar
That sounds like something's not right in the accelerator pump circuit, which could be anything from a bad linkage adjustment to a missing check ball or a ruptured diaphragm inside.
If you work the carb by hand (with the air cleaner off), do you see two nice streams of gas squirting out into the primaries? Or is it only a dribble (or nothing at all that you can see)?
My guess is that the power valve is OK, otherwise it might not even like gently increasing the rpms under load.
Norm
Norm Peterson is offline
Old 04-23-2011, 01:23 AM
DenDen
DenDen's Avatar
I agree its probably the accelerator pump circuit,check to see if the linkage is doing its thing cause you can put the carb together and not get the linkage right,then no squirt.
DenDen is offline
Old 04-23-2011, 03:57 PM
MustangFTW
Guest
Posts: n/a
please start a new thread for this, what your doing is known as thread hijacking.
to answer your question though it should be vertical when warm, there is something seriously wrong with your carb if its closed when warm.
bradleyb
11-27-2015 07:50 PM
fastbackford351
10-01-2015 12:24 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
guitarman376
09-30-2015 05:54 PM
Drastang
09-29-2015 03:31 PM
Quick Reply: Help with Carb setup
