holley hesitation
Old 05-08-2011, 02:49 PM
boogerschnot
boogerschnot's Avatar
You may just need to clean up the balancer with a wire brush to see the markings
boogerschnot is offline
Old 05-08-2011, 04:03 PM
Rat fink
Rat fink's Avatar
Get under the car with a wire brush and have someone turn the engine over, by had, until you see the timing marks, Clean the area good and take some whiteout and put on the damper wear the timing is that you want. Make sure you have the timing light hooked to Number 1 spark plug and fire it up again.
no change in RPM after remove the vacuum line is a different issue, Probably the centrifugal advance is broke/not working.
Rat fink is offline
Old 05-08-2011, 04:22 PM
66 tang
66 tang's Avatar
What is a centrifugal Advance? I know what the vaccum advance is, sorry I'm a bit of a noob when it comes to tuning engines.
66 tang is offline
Old 05-08-2011, 05:01 PM
gjz30075
gjz30075's Avatar
They are a set of small weights inside the distributor that are connected to the plate with the points. As the engine accelerates, the weights move outward, (centrifugal force) and move the plate with the points to advance the timing.
gjz30075 is offline
Old 05-08-2011, 07:19 PM
Rat fink
Rat fink's Avatar
What GJZ said
Here’s a picture of your centrifugal advance. It's under the plate that your points sit on. Take that plate off and see if the 2 little springs are still attached.
Rat fink is offline
Old 05-08-2011, 08:33 PM
66 tang
66 tang's Avatar
Hmm, last winter when I changed the the cap and rotor the springs felt fine. So I checked the timing, set the idle at 800 rpm and disconnected the vaccum line and plugged it, and the timing was at about 5 degrees before top dead center, also put new plugs in today, what do you guys think? Advance it?
66 tang is offline
Old 05-08-2011, 09:35 PM
PaulS
PaulS's Avatar
You can't just advance your timing until you know where its at.
Just a thought here but you are running an air gap manifold - if there is no manifold heat then you are likely to get a bog when accelerating and a bigger cam will make it even worse. I suspect that the issues you have can be tuned out but you will be just hiding the root problem.
PaulS is offline
Old 05-08-2011, 10:15 PM
66 tang
66 tang's Avatar
My timing is at 5 degrees B.T.C. And I've felt the manifold while it's running and it seems warm, I don't know what heat it's ideally supposed to be at, and the cam isn't very aggresive, so I've been told
66 tang is offline
Old 05-09-2011, 08:27 AM
kalli
kalli's Avatar
check on the timing again with vacuum disconnected.
you say you are at around 5degrees BTDC. slowly rev the engine (higher and higher) and see:
a) does the timing change (it should advance more and more)
b) at what rpm does it max out and what is the timing at that point (what is max advance rpm and timing)
the accellerator pump: if misadjusted it will bog every time you pres the pedal. But once you have the foot down and keep it down it doesn't do anything anymore. So I don't think that's your problem.
kalli is offline
Thunderball
15
11-22-2015 11:49 PM
Omgitsa88Stang
10-05-2015 07:33 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
LiquidDrink
09-29-2015 10:06 AM
SteelerNation82
09-16-2015 07:11 AM
Quick Reply: holley hesitation
