WHAT TYPE / SIZE CAM 302 ROLLER
A alphabet cam will still cost you at least $100-150 and they're old crappy cams. A custom grind from Ed will cost you $325 for a hyd roller, and it will be specific to YOUR car, ideal for what you want, and you get free tech help from Ed whenever he can answer emails.
Sometimes he gets swamped and takes a while to get back to you. I'm trying to order some stuff from him right now and he is only getting back to me like once a week, where it's normally every day. But the thing too, is custom grinders aren't always willing to divulge info about cam profiles, since it's proprietary. Aggressive or mild are relative terms...you get a custom cam ground for what you want it to do with your combination...and it does it, whatever the profile may be, it's for what you need it to do. In the end who cares what the specs are, as long as it gives you the most power where you want/need it. That's often why custom cams have oddball specs compared to OTS stuff.....my cam for example has a considerable amount more of duration on the exhaust side, but more lift on the intake side. It is what it is.
That's true. You can get a cam ground to work with the springs you have, but an upgrade to something more technologically advanced is a huge step forward. I'm running LS1 Beehives from PAC with locators that Ed had made up to slip the LS1 springs into a SBF head.
i found my lobes with the same specs in the comp catalog. are those really the same lobes, i have no idea. you can find OTS cams with split patterns in the comp catalog.
why did the cam card for my "custom" cam designed for MY car say an RPM range for a 347-363 when i have a 418? i have my guesses.
one thing you definitely get with a custom cam is the ability to tell everyone you have a custom cam and the belief that it's going to make more power than anything else available.
i'm in no way saying he's not a good designer. there are just people out there that could be taking advantage of people on the forums and internet with not a lot of experience.
he took about 1-2 weeks to get back with me too. he just never answered any technical questions i asked. he instead told me nice things about his family and why the delays.
The rpm range listed is based on the type of cam...like a stroker/streetsweeper will list the rpm range "nominally" for that class of engine(roughly) but will vary from cam to cam. It's just a ballpark figure for the typical rpm range of cams in that category that people get. Whether the lobes are comp lobes or not, who knows...some may be, some may be proprietary....but even then, he's selecting specific lobes and lsa/valve events based on what the engine will need.
was it this statement?
11-10-2015 11:39 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
09-08-2015 06:25 PM
09-03-2015 07:14 PM
