Who Make Repo Fuse Panel?
I am starting to have some strange low voltage issues inside the cab of my '69. Things like the cigarette lighter, and some of my accessories are not reading good voltage. The condition of my fuse panel is pretty poor. Anyone know who makes or where you can buy a reproduction fuse panel? I do not care if it is blade fuses, but would like for it to clip onto the factory engine wiring harness. I am not in the mood for a painless wiring install. My experience with them is so so.
Thanks!
Thanks!
You might check your grounds, too. With a volt meter connected to the negative battery cable, see if you read any voltage anywhere you can ground the positive lead. All accessories need to be working to do this right. If you can read more than .5 volts or so doing this, your low voltage is ground related. Too many people forget the negative side of current flow problems and wind up chasing the wrong ghosts. Connecting the leads across the lighter or other source won't work - the negative needs to be attached to the battery and positive needs to be attached to various ground locations while they are under load. 0 - .3 volts and you're good to go.
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
