residual valve on a 69 stang bad
So, it's leaking through the weep holes so I assume it's bad. Now, I see kits to rebuild them. Is this a standard 2lb residual?
What are you guys doing, buying aftermarket or rebuilding yours? I have not found anyplace that has rebuilt ones.
I see the info on rebuild instructions but I am thinking a rebuilt one is nice as what if I mess it up.
Thoughts? If I do it, what do I clean it out with, brake cleaner?
If you are seeking advice on the Distribution block as GT has shown, then yes, it needs rebuilding.
Dan @ Chockostang
The 69 has a barrel shaped residual valve that is about 2 inches long and 3/4 inch around that is right next to the proportioning valve. I would recommend rebuilding it . I don't believe they are availible new. If you mess it up I guess you will need to find a used one.
Okay, I hear these called many different things. Isn't this just a residual valve? So it's either rebuild or buy used till it breaks or get an aftermarket, right?
is this 2, 4, or 10 pound residual?
You need the rebuild kit to build it, We have them.
Dan @ Chockostang
So, the valve in the distribution block is just monitoring the pressure front/back and not proportioning?
