is carb spacer on 4v bright alu?
RE: is carb spacer on 4v bright alu?
The most common spacers are manufactured from aluminum. Phenolic spacers are constructed from an advanced material (a plastic-type compound) that can reduce heat conductivity 10 times greater than aluminum. The result, of course, is a denser air/fuel charge. Phenolic spacers are constructed from layers of material. As expected, heat reduction is significant when compared to a common aluminum spacer. Believe it or not, plywood also is an ideal material for constructing carburetor spacers. Typically, wood spacers are manufactured from top-quality hardwood plywood with a sheet of phenolic resin-impregnated paper bonded to both sides.
