'66 Convertible Floor, Torque Box, & Rocker Question
I have a '66 convertible that I recently started storing on a lift. I noticed that when on the lift, the doors were hard to open and close. When the car is on the wheels the doors work okay. I suspect that the pans, torque boxes, and rocker panels are rusted to the point that they are letting the car sag (or rise) in the middle. I have several questions: 1. Is this a job that I want to undertake (I have a good shop but I'm 68 years old with bad legs)? 2. Should it be done with the wheels on the ground? 3. Is there anywhere out there that still has original Ford sheet metal? and 4. If I have it done, what is a reasonable price for the job? Thanks
My car has (or had) minimal rust on it. When I put it on a lift, the gap at the doors would open to approximately 3/8 of an inch. I then put on sub-frame connectors. Now on the lift, the gap moves from a little less than 1/8 on the ground, to 3/16 up in the air.
While this won't fix any major rust issues you have, it may buy you some time.
Having just put a full rocker in my '65 coupe it is a pain the butt big time!!!
The repop rocker was 1" too tall and about 3/8" too wide, it was a total pain to get in. It was not squeezed tight enough from the factory on the height and the wire channel on top was made too wide.
Lynn
Lynn
I would first investigate what part of you car that is not 100% before deciding you need a new floor.
I would not recommend replacing that yourself if you haven't done some sheet metal replacement in the past. Any experiance is better than none.
I would guess a complete new floor including conv specific parts would cost about $8k to have replaced at a body shop.
