NEED HELP CHOOSING CORRECT STALL
Based on your curves I'd say you overstated some of the rest of the data due to the high output. Still, it might be useful for conversation but I'd hate for the OP to think he was getting 390hp out of just an E303.
I can't back it up, seat of the pants thing....... (but I can smoke my 15" wide M/T drag radials at will......)
My way of thinking had changed when I built this engine. We built Jim's 408 with a cam that is too radical for the street, it is OK, but it became a pain in the *** after a while.
When I built my engine I was thinking that a Vic Jr. headed 408 9.2 to 1 c/r would make plenty of power with a "mild cam" (like a e-303) and it does.
(the efi I used maxes out at 425 hp on the baseline injectors, so 425 was the max I was looking for, I think I get pretty close)
I always read these "stall speed" threads with a smile on my face. People are SERIOUS about this stuff. I can't add anything of value, since I'll die with a stick shifter in my hand, but from my POV, these threads are similar to people talking about politics!
I am not calling anybody out, just giving an observation.
Probably the closest thing to choosing torque converter stall speed over in the manual tranny world is picking out a flywheel diameter and weight. But the average MT enthusiast doesn't go that deep into the powertrain, and I suspect that the folks who actually do - aren't talking.
What surprises me with respect to torque converters is not seeing any mention of stall ratio either in these discussions or in any of the catalog descriptions. Though I guess it would first have to be in the advertising before it would ever creep into most folks' discussions.
Norm
Norm
You really have to conduct trials in a lab enviroment, too, for stall ratio to matter. The closest the consumer comes to that is pro or semi-pro drag racing with track dedicated cars. What % of the market do you really think is buying converters for that use?
I'm guilty of deliberate build up of the flywheel and clutch combo. My problem is the same as 98% of the performance torque converter buyers. My cars aren't dedicated to one use. If you drive your car around town at all, then go drag racing one weekend, road racing another, or even just want to really enjoy a seriously twisty road, you can't choose a clutch/flywheel combo that is right for everything.
I did pick the heaviest chunk of iron I could get for my old hotrod, but I'm building an aluminum LS1 with a pal to go in his pro-touring '67, too. That one has been lightened, balanced to the 'enth degree and is getting a tiny little multi disc clutch. I'm sure you get the reasoning in both.
When I can clearly remember mention of stall ratio along with seeing a few numbers somewhere (2.2-ish, IIRC) it just seems like something's missing.
Norm
The point I was making (while acknowledging the 408) is that good power CAN be made with a fairly mild cam and good breathing heads.
Relax, I didn't mean to pick on you..............
