1967 front frame rail - MustangForums.com
Old 08-02-2011, 05:53 AM   #1
zarkon0007
Default 1967 front frame rail
hello all. i am new to this site and new to restoring so you may have to bare with me. i need to replace the rh front frame rail on my mustang. i have found the part i need and the front frame brace that goes under the radiator support. there is a cross member that goes from the right front tire arm to the frame member connected by an adjustable rod. i need to replace this cross member but cant seem to find one. is it replacable with new or do i have to get second hand. also when i get the frame rail itself are all the brackets that need to be on it on it or do i have to cut them off the old rail and reuse them.
any help would be appreciated
thanks
zarkon0007 is offline   Reply With Quote
Old 08-02-2011, 12:59 PM   #2
zmetalmilitia
There are replacements for that available now, I've seen them in the NPD catalog, page 182. They are called the support bracket, strut rod. These are the supports that go from the radiator support to the frame rail. Are these the parts you're looking for?
There are no brackets on the frame rail itself, you will need to reuse your old brackets. Unless there has been another release of frame rails lately, someone is always updating these parts to make them better. But when I did mine, it was only the frame rail, no brackets.
zmetalmilitia is offline   Reply With Quote
Old 08-04-2011, 09:13 AM   #3
zarkon0007
Default thanks
that was pretty much the info i was looking for. i am pulling the motor and tranny today and getting the car ready for its operation. i will be putting on a ford alluminum intake and a holly four barrel while the motor is out. i am sure i will have more questions as this goes on.
thanks
Old 08-04-2011, 10:29 AM   #4
zmetalmilitia
No problem. You can find answers for pretty much anything here. Good luck!
WTB Kona Blue GT Front Bumper Cover winner99 Want To Buy Ads 0 10-01-2015 02:06 PM
WTB 11-14 GT Front OEM Sway Bar winner99 Want To Buy Ads 0 10-01-2015 11:52 AM
Colgan Custom Bra for 2014 Mustang mdg Parts For Sale 0 10-01-2015 08:04 AM
GT500 front LCA question UrS4 S197 Handling Section 1 09-30-2015 11:13 AM
Fuel Pump for 98 3.8L model. Not sure which type? mrappe V6 (1994-2004) Mustangs 0 09-26-2015 11:16 AM
1967, 68, chassis, classic, convertible, ford, fornt, fraim, frame, front, mustang, rail, rails, replace, support
