ADDING A SUPERCHARGER- AM I CRAZY OR NOT? - Page 2 - MustangForums.com
Old 08-13-2011, 04:01 PM   #11
JMD
JMD's Avatar
Oh yea, if supercharging a SBF, I consider a main girdle a MUST.
JMD is offline   Reply With Quote
Old 08-14-2011, 03:11 PM   #12
cprstreetmachines
A few psi isn't going to hurt anything. Knowing the CR would help. But the carb doesn't have to be anything special. May work fine stock, may need the power valve externally referenced to make sure it sees the right signal. An upgrade fuel pump should be all you need since it's draw thru.
cprstreetmachines is offline   Reply With Quote
Throwback Thursdays: The First Mustang TV Ad MustangForums Editor Mustang News, Concepts, Rumors & Discussion 2 10-05-2015 08:40 AM
4 Valve Head questions GimpyHSHS 4.6L (1996-2004 Modular) Mustang 6 10-01-2015 10:01 AM
20 inch Wheels a mistake on 2015 Mustang GT? mungodrums The New S550 2015-2017 Mustang 10 09-28-2015 11:54 PM
When would you tune? firecoyote The New S550 2015-2017 Mustang 28 09-27-2015 03:37 PM
O2 sensors Big Al's 03 Mach 1 Section 4 09-21-2015 08:59 AM
174supercharger, 302, 670, avenger, cast, crank, ford, heads, jr, supercharger, supercharging, windsor, work
