T-5 Kit
T-5 Kit
Anyone have experience with the cable clutch kit from CJ Pony Parts? Literally seems like a bolt on project.
http://www.cjponyparts.com/t5-transm...1970/p/T5CK14/
If you have the OEM power brake, you can't use any of the cable setups I have seen, since the cable and the booster are in the same place. Many aftermarket boosters won't work with stock clutch linkage.
I was driving a T5-equipped 65 Mustang yesterday, it had stock clutch linkage.
I've done the cable clutch conversion right at the time that i was upgrading to power brakes. Depending on the kit you buy it is very compatiable and easy to do. My kit came with a reinforced plate that needed to be mounted behind the brake booster. The plate also had a mounting point to where the cable linkage was ment to go. I like it and Haven't had a problem with it since.
Good luck
Good luck
jwog666
12-27-2021 08:09 PM
