V8 Spindles? - Page 2 - MustangForums.com
Old 08-31-2011, 09:28 PM   #11
degins
degins's Avatar
Quote:
Originally Posted by wonso79 View Post
1965 Inline 6, converting from 4 to 5 lug project. Eventually I will be converting to a V8.
If you wish to upgrade your 6 cylinders cars brakes to 8 cylinder type, either drum or disc, you should also upgrade the steering linkage. This involves swapping in a V8 center link, pitman arm, idler arm and bracket, inner and outer tie rod arms, and tie rod adjusters. These are widely available.
degins is offline   Reply With Quote
Old 02-10-2014, 11:10 PM   #12
lucasp
lucasp's Avatar
Are the 1965 I6 spindle to weak to handle a V8 engine?
lucasp is offline   Reply With Quote
Caster/Camber Alignment Question winner99 S197 Handling Section 3 09-30-2015 08:04 PM
93 cobra rear end/ front spindles?? KillSwitchNY General Tech 1 01-10-2006 01:38 PM
86 GT swap to 87 Spindles, any issues? + 17x9 w/coilover troubles.. CrdStang General Tech 1 09-19-2005 02:02 AM
V6 Spindle vs. V8 Spindle 67CarolinaCoupe Classic Mustangs (Tech) 5 09-13-2005 08:22 PM
2' drop spindles eZ Classic Mustangs (Tech) 6 07-13-2005 01:53 AM
1965, 1966, 2008, 65, 66, buy, c3oa, c5da, code, ford, front, mustang, sale, spindle, spindles, v8
