1967 Mustang 9" rear value
Old 09-05-2011, 11:00 AM
VeroWing
VeroWing's Avatar
Default 1967 Mustang 9" rear value
Last week I bought a 1967 coupe parts car that has a 9" rear in it. Yesterday I removed it and took out center section for indentifying. My car already has a 9" rear in it, so I'm looking for opinions on what I should sell this one for. Hers the info I have on it:
HOUSING-----------53 1/2-54" outside flange to flange
SPRING PERCH------44" center/center
AXLE BEARING------2.892" w/tapered axle tubes
AXLES-------------28 spline/straight/no taper
CENTER SECTION---C7AW-E 46
RING GEAR---------C2AW 4210 F has 35 teeth (3.50 ?)
LSD TYPE----------Equa-loc with 4 spider gear/3 pin hooded/guarded
pinion housing
So unless I'm mistaken, this is a posi type rear with 3.50 gears.
This is all the info I've come up with so far. Can anyone give me a ball park asking price for this rear with this info, complete with backing plates, drums, brake parks, but without yoke, which is not there?
VeroWing is offline
Old 09-05-2011, 11:18 AM
2+2GT
2+2GT's Avatar
pinion housing
Although "posi" is a common slang term for limited slip, it's derived from "Positraction™", a General Motors trademark. Positraction is an excellent limited slip, which uses bearing thrust from torque applied to the axle gears to increase the friction loading of the clutch pack to increase the limitation of axle spin. Ford's "Traction-Lok™" works the same way. However, Ford's earlier "Equalock™" has no such sensitivity, it applies a constant pressure on the clutch pack with a Belleville spring, which does not vary with engine power or torque applied. The value of your differential will depend to some extent on which type you have.
2+2GT is offline
Old 09-05-2011, 12:01 PM
VeroWing
VeroWing's Avatar
Its the Equalock one.
VeroWing is offline
Old 09-06-2011, 05:53 PM
ponyboychris
ponyboychris's Avatar
FYI, To find out the gear ratio, count the number of teeth on the ring (35 in your case) and divide by the number of teeth on the pinion gear.
ponyboychris is offline
Old 09-07-2011, 06:05 AM
VeroWing
VeroWing's Avatar
Thanks.
VeroWing is offline
Old 09-07-2011, 08:06 AM
F15Falcon
F15Falcon's Avatar
I never pay more than $200.00 for any 9" rear end because they are used pieces that may or may not be any good for a future rebuild. I buy rear ends to re-sell after I re-condition them though. Being that it is one of the more desireable 9" rear ends beacuse it can be swapped into a car that originally came with an 8" or a six cylinder car, someone may want to pay a little more for it. I would say it is worth $300.00-$400.00, maybe a little more.
F15Falcon is offline
Old 09-07-2011, 02:43 PM
VeroWing
VeroWing's Avatar
Thanks
VeroWing is offline
Old 09-07-2011, 10:43 PM
Cruzzar
Cruzzar's Avatar
Isn't a stock mustang 43" center to center on the spring perches?
Cruzzar is offline
Old 09-08-2011, 07:05 AM
VeroWing
VeroWing's Avatar
I'm not really sure, and my measurement was quick, I'll double check it.
VeroWing is offline
Old 09-08-2011, 02:47 PM
VeroWing
VeroWing's Avatar
Looks more like 43 1/2".
VeroWing is offline
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
MtnMustang
08-16-2015 08:07 PM
PearlGenPu
08-12-2015 01:57 PM
daytooday
08-11-2015 09:22 AM
Quick Reply: 1967 Mustang 9" rear value
