Cleaning rust off of engine block
Old 09-07-2005, 11:16 PM
tylerdru
tylerdru's Avatar
Default Cleaning rust off of engine block
I want to take all of the rust of my engine block what methods would i use? sandblasting? Is this expensive?
tylerdru is offline
Old 09-08-2005, 07:31 PM
ivanr77
ivanr77's Avatar
Default RE: Cleaning rust off of engine block
sandblasting would be the ideal thing to do.
ivanr77 is offline
Old 09-08-2005, 07:45 PM
Soaring
I ♥ Acer
Soaring's Avatar
Or bead blasting, or just plain old elbow grease with sand paper. Some guys also prefer using paint remover to get the old paint off, then using either a wire brush or sand paper to get down to shiny metal, afterwhich you would use a primer then the color coat. Unless the engine has been removed, sand blasting tends to get into the engine components.
Soaring is offline
Old 09-08-2005, 09:16 PM
tylerdru
tylerdru's Avatar
Looks like right now my bidget requires elbow grease. is the paint remover special or just like normal mineral spirits?
tylerdru is offline
djbigskrilla
09-20-2022 01:04 AM
eastexsteve
3.7L V6 Technical Discussions
12-04-2015 05:41 AM
MusicCity615
09-27-2015 12:53 AM
Gary Ugarek
08-26-2015 08:41 AM
KEM Motorworks
08-14-2015 10:13 PM
Quick Reply: Cleaning rust off of engine block
