Scarebird Classic brake kit
Old 09-29-2011, 01:35 PM
  #21
67t5ponycoupe
67t5ponycoupe's Avatar
The other problem I found with the scarebird kit is the kit changes the back spacing required for the front wheels. I was forced to run 3/8th spacers to get my 15x8 Shelby Cragar wheels to clear the upper ball joint. When I changed to the CSRP kit I could get rid of the spacer.
67t5ponycoupe is offline
Old 09-30-2011, 01:56 AM
  #22
andrewmp6
andrewmp6's Avatar
Ba mustang if the s10 calipers are b52 wilwood has a twin piston replacement for it.
andrewmp6 is offline
Old 09-30-2011, 09:04 AM
  #23
1slow67
ROTM Moderator
1slow67's Avatar
SSBC also makes a 2 piston upgrade, wilwood is way cheaper as well. You can get the wilwoods for $320. I might buy them
1slow67 is offline
Old 09-30-2011, 09:36 AM
  #24
andrewmp6
andrewmp6's Avatar
I'm a tard its d52 lol they also make a bigger single piston for the d154 calipers i just can't remember which one the s10 used.The d52 replacement one is 374 on summit and jegs tho.Maybe try one of the vendors on here they might get you a discount on them.
Old 09-30-2011, 10:43 AM
  #25
1slow67
ROTM Moderator
1slow67's Avatar
Yeah I saw the D154 on summit as well
1slow67 is offline
Old 09-30-2011, 02:41 PM
  #26
67t5ponycoupe
Look at swap number 1 on this page http://www.discbrakeswap.com/parts/parts It comes with everything you need and the price is very good. Easy to do with easy to follow instructions. You will be happy you went with this kit.
fastbackford351
09-12-2015 09:42 AM
DoctorScary
09-09-2015 07:53 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
09-08-2015 11:50 AM
Quick Reply: Scarebird Classic brake kit
