70 gas tank in a 67
Old 09-27-2011, 05:28 PM
Rols574
Rols574's Avatar
Default 70 gas tank in a 67
I read somewhere that you could put a gas tank of a 70 mustang on a 67 along with the 70 sending unit to upgrade from a 16 to a 22 gallon tank
Anyone has done this or know if this is true?
Thanks
Rols574 is offline
Old 09-27-2011, 05:59 PM
ozarks06
ozarks06's Avatar
I put a 69 20 gal tank and sender in my 65. Just had to trim the filler tube to make the bend.
ozarks06 is offline
Old 09-27-2011, 07:15 PM
2+2GT
2+2GT's Avatar
Yep- The 70 tank is nice upgrade for any 64-69.
2+2GT is offline
Old 09-27-2011, 10:03 PM
wgc68nyc
wgc68nyc's Avatar
Thanks
I just did it...check a page back on posts. If fit fine though the filler neck needs to be tweaked to make it work. You gain about 4+ gallons from going from 16 to 22. You also lose the slight indent in the trunk...everything will basically be level.
I suggest getting the kit from CJ pony...its just a bit over $100 and come with everything including the correct gas guage sender.
wgc68nyc is offline
Old 09-28-2011, 03:28 PM
Rols574
Rols574's Avatar
thanks. I recently bought a new tank because rust had made a few holes and not 2 months later a bad road dented the crap out of the new one. so off i go to buy another
what a &%$@
Rols574 is offline
4cylinderplus2
10-09-2020 07:45 PM
Sixer4Life
10-12-2015 04:26 AM
b8checker
10-08-2015 12:55 PM
b8checker
09-30-2015 07:11 AM
mrappe
09-26-2015 10:16 AM
Quick Reply: 70 gas tank in a 67
