67 Mustang Drum Brake Improvement?
Old 10-06-2011, 12:35 PM
Mystang66
Mystang66's Avatar
Default 67 Mustang Drum Brake Improvement?
I'm restoring a 67 Mustang and want to keep it as original as possible. I'm trying to stick with the drum brakes but since I will be driving this somewhat regularly, I want to know if there is some sort of performance drum brake setup out there that is more responsive and safer?
Mystang66 is offline
Old 10-06-2011, 02:27 PM
fastbackford351
Foghorn Leghorn
fastbackford351's Avatar
Location: I reside in a near constant state of amazment.
I'd suggest falling out of love with the drums and go with discs if you're going to be driving it and be done with it.
But I think the drum setups out of cars like Galaxies & Tbirds setups would bolt in without too much hassle.
I'd be surprised if they didn't.
fastbackford351 is offline
Old 10-06-2011, 07:58 PM
Starfury
Starfury's Avatar
CSRP sells OE-style disc conversion kits. They're affordable and they work very well (I've got one on my '67). At the same time, you should also switch to a dual-bowl master cylinder, which is generally included in the kit. It's much safer than the original single pot m/c.
Starfury is offline
Old 10-06-2011, 08:31 PM
scootchu
scootchu's Avatar
Yep, CSRP sells a performance drum brake that comes in the from of a disc brake kit. LOL
If you were going to change out the drums for performance drums it wouldn't be original, the brake kits CSRP sells would have been on early Mustangs so that would be closer to original than aftermarket drums.
scootchu is offline
Old 10-06-2011, 08:43 PM
2+2GT
2+2GT's Avatar
Actually, the drum brakes, when properly serviced and adjusted work very well in normal use. Warped drums, frozen, or even draggy adjusters, weak springs, all contribute to poor operation. You don't think these cars weaved all over the road when new, right?
I have a 50+ year-old-car, went through the whole brake system a few years ago, new lines, hoses, shoes, etc., stops smooth and straight.
If you were planning hard driving, such as occasional strip or track, live in the mountains, or just drive nutz like me, I'd say get the discs, but if you're just doing routine driving to cruise night, etc., don't bother.
2+2GT is offline
Old 10-07-2011, 06:26 PM
groho
groho's Avatar
If your just cruisin, and your drums are in good shape, including springs, backing plate feet, and wheel cylinders then consider a simple shoe upgrade to Porterfield, Hawk, etc. I've got the porterfield shoes, and I like them allot. The down side is when you first start driving and they're cold. They need to warm up and get heat in them. For what you're gonna spend on larger drums, you might as well go to rear discs.
groho is offline
Old 10-07-2011, 06:44 PM
MustangFTW
Guest
Posts: n/a
ill just hijack this thread quickly:P
does shuddering when hitting the brakes mean there warped?
Old 10-07-2011, 08:52 PM
67mustang302
67mustang302's Avatar
Cobra Automotive sells drum upgrade kits with modern compounds(Kevlar, ceramics etc) in drum kits. It's mainly intended for racing where stock drums are required, but they have street shoe compounds and less esoteric drums(you can get them cryogenically treated if you want).
67mustang302 is offline
FD725
08-23-2015 06:43 AM
Mr. D
08-17-2015 09:53 PM
cvarner131
08-17-2015 07:38 AM
daytooday
08-11-2015 09:22 AM
FD725
08-11-2015 03:43 AM
Quick Reply: 67 Mustang Drum Brake Improvement?
