What sort of MPG should I be getting?
Old 10-18-2011, 11:13 AM
1971mach1
1971mach1's Avatar
Originally Posted by wgc68nyc
I do smell gas now and then so I wonder if I am still running rich.
I would address the gas smell first, the gaskets on the Holley could be leaking.
1971mach1 is offline
Old 10-19-2011, 02:59 PM
urban_cowboy
urban_cowboy's Avatar
Man, I would not use any generalities or fuel economy to determine if you are tuned right. There are just WAY too many variables to even list. I get 13mpg on the highway at 70 turning 3300rpm, but I also burn 1 gallon on even 1/4 mile track run. And that is with a carb that is tuned right. Concentrate on getting your carb tuned correctly with with a dyno tune or a AFR and the mpg will be whatever it is. Gapping you plugs more should help with economy given that you are getting enough voltage to the plug, but it is going to hurt your performance at more full throttle.
urban_cowboy is offline
squishbang
12-04-2015 02:29 PM
Scottyboy187
SVT Forums
11-20-2015 02:57 PM
stark777
09-21-2015 12:46 PM
algregory
09-11-2015 11:44 AM
Cin K
09-02-2015 07:50 AM
Quick Reply: What sort of MPG should I be getting?
