Traction bars
Traction bars
What are the best and the best place to buy traction bars. I am getting really bad wheel hop since i put on the new tires.
I have an exploder rear end so i am sure i may need to alter the spring plates to make them fit but no biggie!
I would consider cal tracs the "best" but even cheap slapper bars should cure your wheel hop...You could also try clamping the front side of your spring leafs..Make sure your front spring bushings are in good shape without alot of slop...
Ive got traction masters - work fine.
http://tractionmaster.com/app.html
I used to have some lakewood traction/ladder bars back in the day, those things were sweet. My car would lift up an inch when I'd romp on it. No hop --ever!
At any rate, you can get some universal traction bars for ~$80.
http://store.prestoliteperformance.c...l?limit=36&p=1
