where to start with broken motor
Out of curiosity, the gear on the disty, is that still ok?
Honestly, I'd pull the oil pump and take it apart. See if there's all sorts of crap in there. The screen should be able to filter out most things, but I've snapped a oil pump drive shaft or two from super tiny pieces getting by it.
The loud bang, well, that could be a number of things. Although, to me, it sounds like you spun a bearing.
I don't think pulling apart the upper end is going to lead you anywhere quite honestly. You need to pull the motor and do a thorough check.
Pump looks good...Ill definatley take it apart before putting the motor back together. Pushrods are all good. Connecting rods look fine. Ill have to take a look at the camshaft. I can turn the motor just fine. and I dont think I can feel a wobble. How do I check for bearings? I guess everything will have to come out. Perhaps just get it down to the shortblock and have a pro put it together. LOL yea right.
Ill jump on that tomorrow...need to go buy a good torque wrench first. Should I check crank bearings or rod bearings first? How bout cam bearings. Will it be pretty obvious which one is shredded? Do you think the motor is going to have to come out anyway? if so Id like to save myself some hurt under the car. My knee is pretty jacked up right now.
you can replace cam bearing with the engine in the car...but id just pull it out cause it doesnt take long and youd have it up higher with better access instead of leaning over...
