where to start with broken motor
#23
you should check all the bearings, but I don't think if they're worn or you spun a bearing that would not be the original problem.
I'd go back to that oilpump. just the fact that you lost the pressure instantly after the bang sounds to me that either the oil is now going somewhere where it shouldn't, but that would have contaminated your water or combustion chambers. If water is clean and theres no oil in chamber, then I really think the only problem can be the oilpump. that it suddenly decided to die.
I'd pull that out and inspect it ... if you're lucky (can you call it that?) it's just that ...
#24
Kalli is right, oil pump is the lesser of many evils and since you have the pan dropped, easy to check.
#26
You know after thinking about this more. I drove my car to the exhaust shop with open headers. I didnt notice the noise till we put exhaust on and drove off the lift. Its possible i could have happened on the way to the exhaust shop and I didnt hear it. about 5 miles of a drive. I do remember it wasnt holding an idle on the way down to shop.
#27
Oil pumps don't normally just fail unless they get debris from something else stuck in them..Needle bearings from a failing roller rocker for example...If the engine is full of metal shaving you will need to pull it and disassemble it for cleaning..Once metal is in the oil passages it will circulate through everthing and cause lots of scoring and damage..If you post pics of the shaving someone may be able to identify what it might be from...Also if you spun a bearing it might be loose enough you can feel the clearance by just wiggling the bottom of the connecting rod..
#28
#29
