Voltage reulator
Old 11-02-2011, 08:47 AM
Stang 65
Stang 65's Avatar
Default Voltage reulator
Hi all,
In the process of replacing my altenator on my 1965 mustang. They suggest that I replace my voltage regulator. Can some tell me where it is located.
Thanks
Stang 65 is offline
Old 11-02-2011, 09:30 AM
Soldier GT
Soldier GT's Avatar
welcome...
Soldier GT is offline
Old 11-02-2011, 10:01 AM
All4One
All4One's Avatar
Welcome to the forums. I believe that is the little box on the back of the alternator housing.
All4One is offline
Old 11-02-2011, 10:24 AM
All4One
All4One's Avatar
I like to type my answers without doing any research first...
Looks like it's been moved in newer cars. Labeled here as "alternator regulator" next to the headlight.
And here's the rest of the '65 diagrams just for giggles.
http://averagejoerestoration.com/res...ring-diagrams/
All4One is offline
Old 11-02-2011, 08:43 PM
2005Redfire6
2005Redfire6's Avatar
Welcome to the forum!
2005Redfire6 is offline
Old 11-02-2011, 09:06 PM
Templar
Templar's Avatar
Welcome to MF
Templar is offline
Old 11-03-2011, 11:32 AM
mygt500
Multi-Tasking Moderator!
mygt500's Avatar
welcome and moved to the right tech section for you!
mygt500 is offline
Old 11-03-2011, 01:11 PM
Stang 65
Stang 65's Avatar
Thank you for info All4one. The diagram will come in handy. I finished replacing the altenator last night. Should I replace to regulator. Would it cause problems if I don't?
Stang 65 is offline
Old 11-03-2011, 03:04 PM
jlg2002
jlg2002's Avatar
both the alternator and the Vreg control the charging system and either will prevent correct operation. I would not arbitrarily replace the Vreg without doing a charging system test. simply hook up a voltmeter across the battery and start the engine , raise the idle to about 1500 rpm and note the voltage reading. if above 14.8 or so. the Vreg and alt are good- no further work required.
If below 14.8 but above 13 it may be wise to replace the Vreg but check that the Alt belt is tight first.
If battery voltage is 13 or below, you need to determine if the alternator is putting out enough current. You can do this by unplugging the V reg plug and momentarily jumping between the B and F terminal to alt should whine and the voltage should go way up. if it doesn't the alt is bad. if it does the Vreg is bad.
jlg2002 is offline
Old 11-03-2011, 10:24 PM
boogerschnot
boogerschnot's Avatar
Good info but keep in mind that you should sit around 14.8 while running but not more than that. If you are over that, lets say 18.5 at 2000the rpm then you need a new regulator. So if you are down at 13 or 12 then you arent charging.
boogerschnot is offline
Quick Reply: Voltage reulator
