Timing chain advice (timing gear set)/ help
Old 11-02-2011, 05:18 PM
Gun Jam
Moderator
Gun Jam's Avatar
Default Timing chain advice (timing gear set)/ help
Hey
So my timing cover sprung a leak from between the block and the cover. The timing cover is badly pitted along the sealing surfaces and inside the water ports. I bought a new timing cover.
I also noticed that the timing chain is pretty loose and has been on there for the last 8 years probably.
I am highly considering purchasing the edelbrock 7892 timing gear drive set.
I know other than slightly improved timing accuracy they don't really offer much benefit I do like the idea they wont stretch.. But how noisy are they? This is suppose to be the "quiet" set does anyone have a video demonstrating the loundness of a quite timing gear set?
What do you think I should do?
Thanks
-Gun
Gun Jam is offline
Old 11-03-2011, 09:54 AM
scott_m_mil
scott_m_mil's Avatar
DO NOT put a gear set on, they are HELL, I mean HELL on a camshaft. They are always loud, even the 'quiet' ones. And as far as stretch, a good Cloyes chain could go 100,000 miles no problems.
Yes, there is a slight increase in timing accuracy. But unless you're running a race car you'll never notice the difference.
Additionally if you have a 289/302 you will need to modify the inside of the timing cover to clear the gears.
scott_m_mil is offline
Old 11-03-2011, 10:39 AM
Gun Jam
Moderator
Gun Jam's Avatar
awesome thanks for the advice
Gun Jam is offline
Old 11-03-2011, 12:54 PM
eZ
eZ's Avatar
Dude just get a cloyes double chain...lol...i said dude...wtf?
eZ is offline
Old 11-03-2011, 01:14 PM
Gun Jam
Moderator
Gun Jam's Avatar
I think thats what im doing EZ.
Gun Jam is offline
Old 11-03-2011, 01:55 PM
Iskwezm
Iskwezm's Avatar
Im not sure why a gear drive is hell on a cam.Ive had mine for about 16 years on different engines and never had any issues.Is that from personal experience or something you heard?
Iskwezm is offline
Old 11-03-2011, 02:44 PM
Gun Jam
Moderator
Gun Jam's Avatar
is there anything special I should know when changing the timing gears and chain?
Line the dots up
remove the bolt from the cam gear
am I going to need a puller?
Gun Jam is offline
Old 11-03-2011, 09:20 PM
JMD
JMD's Avatar
Line the dots up
Yes
Yes
Yes, one to remove the balancer for sure
and probably one to get the crank gear off, a small cheapo 2 or 3 finger will work fine here, it wont be hard to get off.
JMD is offline
Old 11-03-2011, 09:42 PM
eZ
eZ's Avatar
I was able to pull mine off by hand. But then again I am completely ripped...LOL
eZ is offline
Old 11-04-2011, 01:19 PM
scott_m_mil
Iskwezm:
I have never personally had a problem with a gear drive, I have never personally used one. I have had friends that had them, and then replaced them. I do have to say in those cases the cam, and cam bearings for that matter, were broken in and used with a chain and then switched to a gear. That could have been the source of the issues.
Scott
Quick Reply: Timing chain advice (timing gear set)/ help
