just finished paint :)
Old 04-27-2012, 09:24 AM
  #41
Old Mustanger
Old Mustanger's Avatar
The stang looks great! You should be proud of a job well done, especially for a newb! I would be way too afraid of screwing it up, myself.
Old Mustanger is offline
Old 04-27-2012, 10:00 AM
  #42
68dustin
68dustin's Avatar
thanks everyone.... they are 17" wheels
68dustin is offline
Old 04-27-2012, 11:22 AM
  #43
hightower2011
hightower2011's Avatar
Originally Posted by 68dustin
1. Sharpe all dents on car
2. Work each panel 1 at a time - sand down with 60-40 grit at dent location
3. Fill with evercoat filler
4. Knock down to get "general shape" of car with filler
5. Finish dents with 120-180 paper to feather and smooth out filler
6. After all dents are done, i then began sanding car down (took some spots to metal)
8. Washed and blew out all cracks with compressed air.
9. Wiped car down with wax*grease remover (wear gloves - no skin contact to car)
10. Sparyed the whole car with http://www.tcpglobal.com/restoration...+KIT-KEP506-GL one qt. will do 1 coat pretty easy
11. Found a few more dings, and fixed (you can lay filler over epoxy primer)
12. Cleaned and wax removed car again
13. Bought a gallon & Put 1 coat of : http://www.tcpglobal.com/restoration...=KUS+KPP106-QT This stuff has great filling properties (sanding scrathes ect.)
14. Blocked entire car again with 200 - the black primer after sanding shows the dings really good. The car turns a dark gray after sanded.
15. Repeated the dent fixing process lol, always more dings
16. Repeated cleaning process again
17. Put another coat of primer on car and blocked out with 400 this time. Do not use anything lower or scatches will appear in paint.
18 Repeated cleaning process AND WEAR GLOVES NO SKIN CONTACT ON CAR
19. Taped off car and painted jambs
20. Waited a week and taped off jambs to paint car
21. Blow off car and wipe down with wax grease remover
22. Wipe car down with tack rag
23. Mixed up paint: http://www.tcpglobal.com/restoration...P+UB2701-KIT-M I made sure the garage was at least 70 and all pilot lights were blown out
24. Put 4 coats of base (tack rag in between coats)
25. Put 3 coats of clear (no tack rag)
26. After a week and half i started cutting and buffing. here is the kit i used, pretty beginner friendly. Not the best, but im a noob. http://www.summitracing.com/search/B.../?autoview=SKU
Basically wet sanded and buffed each panel at a time. 2000-2500 sand paper. Took about 2hrs for each panel. (so ya... alot of hours)
Im sure this little write up wont be perfect for some people, but hell I learned everything off reading what people have posted. Asked alot of questions and never went to any autobody school. That and total cost of paint job was around 450.
** my write up was more indepth, but computer crashed and had to start over.. sorry hope this helps
Had to quote it all to bring it over to the next page.
EXCELLENT write. It's simple, but detailed, write-ups like this that really get the ball rollings for others like me. Really has me considering doing my own paint job.
The mustang looks great BTW! Love the rim choice too!!
hightower2011 is offline
Old 04-28-2012, 06:55 PM
  #44
1969boss302
1969boss302's Avatar
Nice job! I am at the paint stage with my project and will be doing a garage spray job just like that in another couple of weeks. btw I love that Cougar! I had a '68 that same color, I do miss that car....
1969boss302 is offline
tmdm
05-02-2021 02:49 PM
Dathan
10-05-2015 05:52 AM
10-01-2015 09:29 AM
mungodrums
09-28-2015 10:54 PM
GLOCKer
09-28-2015 07:36 AM
Quick Reply: just finished paint :)
